Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 54
    Jul 2013
    #31
    Quote Originally Posted by xwangbu View Post
    I have the Mi portable inflator. Good for two tyres yung one full charge.
    Dati yung BnD na multi-purpose - with jumpstarter+air pump+emergency light.Attachment 43103
    ok ba ito? planning to buy one for our vehicles
    Nov 2017
    #32
    I've been using the portable and handy Mi tire inflator for two years already. Napansin ko lang parang ang bilis mag blink ng led from white to red indicating na low batt na habang nag i-inflate ako ng car tire. Pero so far kayang mag inflate up to 40psi kapag fully charged yung battery.
    Madalas ko nang magamit itong Mi tire inflator mula nung bumalik ako sa condo living. I can easily do a maintenance tire inflation before going out.
    Gamit ko din yan sa bicycle
    Nov 2019
    #33
    1 tire lang kaya sa isang charge?
    Nov 2017
    #34
    Tingin ko pwede naman kung sedan tire.
    Oct 2019
    #35
    same experience, red LED blinks after a relatively short while, and seems to struggle a bit when getting to the higher pressures - i have doubts if it can fully inflate 1 tire from zero with one charge. I still like it though because it's handy enough for topping up my tires and inflating bike tires. I like that it gives you a pressure reading and you can set a target pressure where it automatically turns off. I have a 70mai tire inflator in the trunk though - the one that you plug in the cigarette lighter -yhis one works much better - except for the hassle of having to plug it in.
    Jan 2009
    #36
    Portable tire inflators generally have short lifespans and are not designed for frequent use. Only use them sparingly and as last-resort in the field.
    Particularly, if you have your own garage and/or have several cars, get a small air compressor to do the heavy lifting instead.
    Sep 2016
    #37
    I have my digital inflator yung kinakabit sa 12v socket. Still serving me well after 4 years. Got it for 1k sa shopee.
    Jul 2013
    #38
    can you use it while plugged to a power bank?
    Nov 2017
    #39
    Unfortunately no
    Nov 2017
    #40
    What brand? I had some not so good experiences with these kind of inflators that are plugged into the 12v socket.
Need recommendations on tire inflator.
