Page 6 of 6 FirstFirst ... 23456
Results 51 to 54 of 54
    Apr 2012
    #51
    i have this same exact model elevo in the trunk of our car. never had to use it pa. got me thinking i have to check it kung operable pa siya. baka mamaya gapok na din yun hose.
    i think matibay yung hose. its the plastic valve na madaling masira. if you can find the one with valve made of metal better get it. or pwede i DIY na palitan yung valve...
    Sent from my SM-G960F using Tsikot Forums mobile app
    #52
    did it degrade from frequent use,
    or did it degrade despite non-use?
    i have several inflators whose orange hoses crumbled into dust.
    where may i source replacement hoses with nozzles?
    The oldest unit developed a small split/crack. Coiled hose was replaced with PU hose from a pneumatic shop near Soler/T.Mapua.
    I carry backup pumps in the pickups since I go lots of places and jobsites, this Elevo under the passenger seat then a compact Coido pump inside the toolbox compartment of rear seats. The smaller cars and PPVs each have the compact tyre pumps which should be sufficient for emergency use.
    Sep 2010
    #53
    Just topped up my spare using my Mi air compressor. Can't remember the last time I charged it (over 6 months na siguro). Nahanginan naman from 25 to 33 psi w/o going low on battery.
    #54
    i equipped all our cars with similar-model tyre inflator.
    when i needed to inflate my tyre, i got one out and found out that the orange coiled hose had degenerated to friable powder.
    i then got out the other tyre inflators, and discovered that all of them suffered the same fate!
    so, bumili ako ng cheap coido brand. i hope it will not degrade over time.
    sigh.
    i wonder,
    where may i buy replacement hose to replace them coiled orange hoses?
Need recommendations on tire inflator.
