Page 4 of 16 FirstFirst 1234567814 ... LastLast
Results 31 to 40 of 153
    May 2017
    #31
    Related to this... how about if my stock tires are 245/60R18. Should I go with 255/55R18 or 265/60R18?
    Quote Originally Posted by Sebastian Bach View Post
    Wow! Thanks for this! Helpful indeed!
    My stock mags specs for tires is 215 / 50 R17, is there a negative effect if I will use 225 / 50 R17 & go against the stock specs? Just curious.
    As long as tire diameter does not exceed 5% difference, you will be fine. You can use either 225/45/17 or 225/50/17, difference is just around 2%.
    Quote Originally Posted by Shutterbug View Post
    One size going up is fine... two steps higher is risking too much.
    Mar 2018
    #33
    If you increase tire size, chances are you will have increase in fuel consumption.
    Sent from my ONEPLUS A3003 using Tapatalk
    #34
    but what do you expect to accomplish with this "upgrade" ?
    May 2017
    #35
    Ok got it. Thanks!
    Thanks!!
    Quote Originally Posted by RavenBlack View Post
    Just to make it look a bit wider and sometimes depends on the availability of the desired size per brand.
    #36
    With 245/60r18 as OEMs, 255/60r18 will give you about the same ride height. 255/55r18 is too low.
    55 is matagtag also 🤭
    May 2017
    #38
    Oh ok. Thanks for the inputs guys. 👍🏼
    Sep 2014
    #39
    Anyone have any experience with Goodyear Assurance Triplemax 2? Planning om getting a couple for my Swift 1.2 eh, 185/65r15.
    Sep 2018
    #40
    Thanks for this thread as I find it useful and helpful. Will definitely share this to my colleague!
Finding the Best Tire for You
