Results 21 to 30 of 34
June 6th, 2003 11:44 PM #21
Make sure you use the right grease for the poly bushings. They have a tendency to squeak kasi.
- Nov 2002
- 6
June 6th, 2003 11:44 PM #22Originally Posted by wiretap_md
As far as the front is concerned, I don't have any problems with diving under hard braking. I don't remember how it was with the stock shocks up front.
- Gripe
June 7th, 2003 12:18 AM #23
I'm planning to change the bushings of our Trooper soon. I believe the SuperPro set costs P12k at RATS.
Tsikot Member Rank 3
- Dec 2002
- 636
June 7th, 2003 08:45 AM #24cj,
A friend placed OME on his trooper 4x2, after a year of use, he regrets buying them since he finds them too soft. It really rolls on fast corners and bottoms when loaded. He had a pajero w OME, but was all praises on OME in this application.
OTEP,
Where do you source the different models of KYB? I'm using the "super" model (all black) and find it stiff, how much of a difference is the premium model in terms of ride?
- Dec 2002
- 636
June 7th, 2003 09:10 AM #25ARB,
we just changed the shocks of wiretap-md's trooper, same pa rin. nasa valving yan ng shocks. tokico yung brand.
June 8th, 2003 01:06 AM #27
jackaroo,
I get them from MIT-PARTS in Banawe. But if you have the part numbers, I'm sure they can grab one for the Trooper.
Tsikot Member Rank 5
- 3,144
June 8th, 2003 10:58 PM #28Isuzu should ask its trooper buyer to specify its ride comfort condition before releasing the unit, pronounced with a heavy visayan accent.
SOP o MODIRIT :evil:
No pun intended ha :D
- 227
June 9th, 2003 02:59 PM #29[quote="RedHorse"]cj,
Go for RS9000x, then get its in-cab controller. Another brand na may multi setting is Pro-comp, kaya lang, gagapang ka pa rin sa ilalim para baguhin yong setting from soft to firm.
Right now, naka RS900x ako sa front at setting no. 3
Redhorse, magkano inabot yung set up mo?
OT: SOP o MODIRIT ba? he he he
- Dec 2002
- 636
June 9th, 2003 07:13 PM #30OTEP,
Thanks for info.
Have you heard of a shop that specializes in Isuzu parts and may carry KYBs too?
How much of a difference in ride between premium KYB and stock shocks?
