Page 92 of 145 FirstFirst ... 4282888990919293949596102142 ... LastLast
Results 911 to 920 of 1445
    #911
    Hi sir baka may interesado po dito, I have pair of use Bilstein shock (pang harap) para sa trooper, nakakabit po ito sa bighorn ko dati, tinagal ko po before namin ibenta ang big horn.. Here is my number for interested party 09178094541...
    Sep 2008
    #912
    Benz,
    Do you have any idea the difference between Bilstein shock B46-1738-H2 and B46-1738-HOOO if they are both fitted for the UBS69 model? Thanks
    Sep 2005
    #913
    Anyone know where I can get a socket replacement for the headlamp wiper switch? Eto ung nakaplug sa likod ng headlamp wiper switch located sa dashboard ng troop naten.
    Nov 2007
    #914
    Mga Sirs,
    San po nakakabili ng alternator ng 4jg2 (99 trooper 3.1)? How much bnew and surplus?
    Pag idle nasa 12v lang, pero pag mga 2k rpm nag 13 volts sya. Tsaka medyo matigas brake pedal bago i-start makina, pag iniwan overnight (vacuum pump ng alternator?)
    TIA
    Sep 2010
    #915
    Mga Trooper Gurus,
    San po ba ako makakabili ng Step board other than casa?Magkano po kaya 7500 kasi dun e.
    Salamat
    Feb 2005
    #916
    Quote Originally Posted by POPPIX View Post
    Mga Trooper Gurus,
    Salamat
    Try CarryBoy. I believe they used to supply this to Isuzu.
    Aug 2004
    #917
    help naman po. my trooper 4jx1 2003 model idles up and down when cold, and eventually the engine dies.
    #918
    Quote Originally Posted by cHriS20 View Post
    sir kumusta trooper mo? nabasa ko sa ibang thread nag pa change oil and tune up? ano ang ginawa nila?how much the cost?
    Apr 2008
    #919
    Pacheck mo kaya muna sa diesel calibration shop? Ano yung idling rpm mo? According to the owner's manual, 720rpm ang normal idling rpm niya. Taas taasan siguro para hindi mamamatay. At patingin mo kung ano yung cause of erratic idling.
    #920
    i had my trooper service last sept.5 jobs done: change oil filter, fuel filter, the TPS and replace injector the first time...i got it last sept. 7 upon starting it did not start right away it takes maybe 10 seconds before it starts (nagreredondo pero hindi matuloy yung start) i was worried good thing the SA is there and witness what had happen then he told me that maybe the battery is low but i said it is not because its still new then he told me that just observe it the next day...it was till this morning that i experience again the hard start it took a little longer 15 sec. then after going to the market at around 10am i just parked the car at the garage then as i was just to leave at 5pm it had a hard start again but it only took about 5 sec.. im planing to go to isuzu tomorow...
    what seems to be the problem pa help naman mga trooper experts...TIA
Isuzu Trooper discussion
