Results 1,421 to 1,430 of 1445
- Apr 2008
- 6,235
May 21st, 2016 10:21 AM #1421I personally have no problem if the car had an engine transplant as long as it was done correctly with a good engine and has proper documentation.
Sent from my SM-G900I using Tapatalk
- May 2016
- 9
May 23rd, 2016 05:39 PM #1422
- Apr 2008
- 6,235
May 24th, 2016 07:01 PM #1423Baka mali rin yung advertisement at gas engine talaga yun. Icheck ng mabuti...
- Sep 2008
- 595
May 26th, 2016 10:48 PM #1424Yes mayroon, I own a 1997 4JG2 LS manual 4x4 unit since new. It was the first year that the TD came out together with the V6 but with auto trans. It has no fender flares but with a hood scoop for the intercooler, whereas the gasoline version has none. I believe it came out only up to early 1999, after which, the automatic versions came out for the diesel variants
- Mar 2011
- 339
July 18th, 2016 05:42 PM #1425mGa sir san kaya makahanap ng relay sa automatic transmission
trooper 2004 nagloloko na kasi
try ako pasay di kolang nasuyod lahat wala sila
baka my marecomend kayo o my number kayo ng store
TIA
- Mar 2012
- 84
August 5th, 2016 12:14 AM #1426Mga sir, baka meron kayo kilala and pwede marefer sa amin na reliable na mechanic ng trooper. May lumalabas kasi na check engine pagstart ng kotse, tapos hindi siya mawawala hanggat hindi mo ilagay sa Drive. Yun yung napansin namin. May mga ilang beses na minsan wala naman siyang check engine. Pero ngayon, minsan kahit umandar na, nagflash yung check engine tapos nawawala din naman. Hindi ko na kasi makontak yung dati namin mechanic (kuya robert, baka kakilala niyo) kaya wala na matinong nagme-maintain nung trooper. Baka may marefer kayo ulit mga sir. Thanks po.
- Mar 2012
- 84
August 5th, 2016 01:39 AM #1427Pinalitan na din po pala computer box niyang trooper namin mga sir. Sa parents ko po kasi yan. Yung mekaniko, 2-3months ago, pinalitan daw yung computer box, yun daw kasi yung sira, hindi na ata ma-read (i-confirm ko po mga sir)after naman nun, ok na. Wala lang kasi kami makita na matinong mekaniko ngayon nitong trooper. Yung iba kasi, sayang lang pera, parang hindi kabisado and mahal pa sumingil.
patulong naman mga sir. Salamat po.
August 5th, 2016 09:49 PM #1428
Sa dealer talaga dapat pinapaservice ang trooper most mechanics aren't familiar with 4jx1-tc under its hood unlike isuzu's 4ja1 and 4jb1 engines
I know someone who also owned a trooper they spent 300k sa overhaul ng trooper cause they had the car service outside the dealer which is a big no no witht the trooper you should also religiously follow the pms interval of 5k kms change oil and 10k kms for air and oil filter in short maselan talaga ang trooper produced from 1999-2006
- Mar 2012
- 84
August 5th, 2016 11:13 PM #1429thanks sir crosswind sa pagreply po. Yup, we follow po kung ano dapat gawin sa trooper. Nagkataon na ngayon, almost a year na, hindi na namin makontak yung magme-maintain ng trooper namin. And kabisado niya lahat ng sira,problema at kung ano ano pa sa trooper. May gumagawa ngayon, taga isuzu din. Pero nagkakataon lang siguro parang lagi pa din nasisira mga every 2mos may problema. Nagagawa naman pero either may lumitaw na iba or masira uli. Kaya naghahanap sana kami uli na may magrefer dito. Dito din namin sir nahanap yung talagang nakapagpatino sa trooper namin. Before nung hawak pa niya, halos wala talaga sira. Kung may masira man, alam agad and alam mo yung feeling na pagnakita na niya, saglit lang gawa na agad. And kung may remedyo pa, inaayos lang talaga and alam niya kung makakasama o hindi. Na-spoiled ata yung trooper kaya nagtampo. Haha.
- Sep 2008
- 595
March 12th, 2017 07:50 PM #1430Any one here used Bilstein shock absorbers for their UBS69 troopers? Was it a better ride than OEM? Can I have the part number of the front and rear shocks and where did you buy them?
Tesla Philippines
