Page 64 of 64 FirstFirst ... 14546061626364
Results 631 to 640 of 640
    Dec 2010
    #631
    mga boss tanong ko lang po sana. yong A/C ko medyo mahina na at meron daw leak sa hose. Sabi ng nasa shop dapat daw putulin ang hose at ang base nya. yong aluminum na nag hold sa hose. tapos papalitan daw at i-solder. Wala daw set para dito. Tama ba?
    Another thing, may connection ba yong problem sa madaling pagka ubos ng coolant ko sa radiator sa A/C problem ko or completely separate issue?
    TIA sa mga mag reply.
    #632
    Mga sir tanong ko lang kung san banda nakalagay ang idle up switch ng crosswind XUV? Mlakas ang alog ng makina pag nag engage ang thermostat. Kakapalit ko lang ng engine support at transmission support. Pag enganged thermostat hindi tumataas ang rpm. TIA
    #633
    Meron na po ba dito na ngDIY ng mesh grille for 2002-03 model xuv-i crosswind? Or Meron ngbbenta na mesh grille?
    Jun 2017
    #634
    May obd2/euobd port ba ang 2003 crosswind xuv? magkano kaya paayos ng speedometer? thanks
    #635
    Quote Originally Posted by nyx1047 View Post
    As far as i know walang obd port ang crosswind.
    Depends sa sira ng speedo might be sa sending unit, gear sa speedo cable or the gauge cluster itself. I remember noon i had a sending unit replaced with surplus cost me 1.5k pero that was for a different car.
    Jul 2013
    #636
    Speedo? Normally cable lang yan...
    Sent from Zenfone 3 on Tsikot mobile app
    Jun 2017
    #637
    May recommended shop ba kayo para sa speedo? sabi kasi sa casa palitan yung instrument cluster pero di naman chineck yung cables kasi wala raw electrician nila. Ano pala recommended niyo na palit sa stereo kasi maluwag na connection nung face ng stereo. Thanks
    Jul 2017
    #638
    I know Crosswind (XUV) has an OBD2 'port'. It is located on the driver side near the door (under the dashboard). More like at the back of the 'fuse box' but have to access it underneath and not by the fuse box.
    If you ask if it works, it is another question. But why have and OBD2 port if it doesn't work?
    Aug 2009
    #639
    Quote Originally Posted by GMartinez View Post
    Walang computer box ang xwind so no OBD2
    Dec 2008
    #640
    Quote Originally Posted by Sleepcare View Post
    all models po ba walang computer box? I thought it was only the not so higher models.
Isuzu Crosswind XUV/XUVi Owners
