Page 369 of 371 FirstFirst ... 269319359365366367368369370371 LastLast
Results 3,681 to 3,690 of 3710
    #3681
    Quote Originally Posted by bombero_ako View Post
    thanks a lot sir, sana makahanap ako ng maayos na unit.
    There's no doubt about it. Just exercise patience in your hunt.
    Masarap maghanap lalo na kung ready ang budget for it.
    Also, bring a very good mechanic - na kikilatis mabuti.
    I have a friend who brings his trusty mechanic every time he decides to buy a 2nd-hand vehicle.
    Naalala ko kuwento nya: Bilin lagi nya sa mechanic nya is kilatisin mabuti at "pintasan lahat ng puwede nyang maipintas." This way, it gives my friend a good idea on what needs to be done pa sa vehicle and knowing such, how to haggle the last price for the vehicle.
    Naalala ko yung mga hunt namin ni Mrs ko dati whenever we buy second-hand vehicles.
    Suwerte naman at laging maayos ang nakukuha namin (papers and all). Siguro kasi, at the first instance of "duda" or "something is not right," we politely back away kahit gaano kaganda ang itsura ang labas ng sasakyan.
    I also remember, once nakakuha na kami, we change all the fluids (brake, coolant, power-steering fluids).
    And lahat ng sinabi (kung meroon man) ng mechanic ay ipapaayos namin. We also change all the tires to brand new (if the case warrants it). Then, go to a detailing shop. Kapag luma na tint or 4 years running na yung tint, we also change them to new ones. Then, pa-bless namin sa Antipolo and Manaoag, Pangasinan.
    Good luck!
    AK
    Jul 2015
    #3682
    Quote Originally Posted by AnitoKid View Post
    Nagpapakarga ako once a week (Shell).
    Sabay pa-check na rin ako ng tires ko after pakarga.
    Usually yung fuel gauge ng vehicle ay below the halfway mark.
    Nakaugalian ko na hindi isagad to the last line ang fuel gauge.
    1 Liter of Shell 2T ang nilalagay ko tuwing magpapakarga ako.
    Pinalalagay ko muna yung 2T bago ikarga yung diesel.
    This way, nahahalo mabuti yung 2T.
    Also, minsan walang 2T available. OK lang din.
    Sa next karga ko naman ay may 2T na uli.
    The best of luck on your hunt, brother.
    A.K.
    Hi Guys, is it necessary to add 2T oil filling up fuel? Have seen a couple of doing it but is it necessary?
    Thank you.
    May 2016
    #3683
    Quote Originally Posted by bombit View Post
    Thank you.
    Not necessary. Some users swear it smoothens out engine vibrations.
    Here's a study I found with a quick google search. Take note the study was conducted in South Africa.
    2-Stroke Oil In Diesel – A Technical Study
    Conclusion:
    2-stroke oil can contain around 16ppm zinc, or higher depending on the formulation and batch.
    Trace amounts of zinc in diesel are known to rapidly accelerate injector nozzle deposits.
    Engine test results show that a 200:1 blend of 2-stroke oil in diesel results in a 2% loss of engine power in a 16 hour test due to injector fouling, a risk that would apply to any common rail diesel engine, but could also worsen fouling in older engines.
    Vehicles fitted with a diesel particulate filter (DPF) in the exhaust system could experience reduced DPF life due to the collection of ash and metal based contaminants in the filter over time with the continued use of 2-stroke oil.
    Jun 2011
    #3684
    https://www.autoindustriya.com/truck...-php-962k.html
    "Powering the Traviz is a 2.5-liter 4JA1 BluePower direct-injection diesel. If the name sounds familiar, it is because the engine was derived from the Crosswind AUV. It puts out 78 PS at 3900 rpm, along with 176.5 Nm of torque at 1800 rpm, and is Euro 4 compliant."
    Kaya naman pala gawing Euro-4. Puwede pang buhayin ang Crosswind.
    Maganda ma-update sa ABS at Airbags.
    Apr 2008
    #3685
    Ganda sana if they gave it more power while they were at it. But as it is I see droves of jeepney operators getting this. Probably the only old school diesel in the market rated Euro 4. Fuel consumption matching modern CRDis with old school diesel maintenance cost! May nanalo na!
    Sent from my SM-G965N using Tapatalk
    #3686
    hello po. NagpaPMS ako ng Sportivo 2010 namin kanina (plus change oil and ATF dialysis). Per checking nila sa ilalim, ang daming need palitan 😭
    Center Post 3k
    Ball joints 5k
    tie rod 2k
    idler 3.5k
    Transmission Oil seal 4.5k
    wheel bearing 3k
    labor 3.5k
    Makatarungan po ba ang prices? Also, yung ball joints, idler arm, tie rods and center link were also replaced dec 2016. So normal lang po ba na for 3yrs, papalitan sila ulit (Im driving daily house to school ng mga kids po then mga once a yr na long drive, if this will help 😅).
    Also, do you regularly do ATF dialysis? Every when?
    #3687
    Quote Originally Posted by bxr monkey View Post
    Utang na loob pre, wagmona buhayin Napaka hina na ng preno den lalakas ang makina, aksidente aabutin nyan.
    Jan 2018
    #3688
    Hi! Ask ko lang if kaya bang ipush start yun crosswind na MT? 3 years na yun battery eh and na discharge ata for not using for 5 days. Ayaw mag start kasi kanina so nag commute nlng ako.
    Nov 2011
    #3689
    Quote Originally Posted by ferddie View Post
    Pa deliver ka na lang ng battery. Di na uso tulak tulak nowadays.
    Or use a jumpstarter.
    #3690
    palitan mo na via delivery. sulit na yan sa 3 taon kesa sa labas itirik.
Isuzu Crosswind Owners Thread [continued]
