Results 531 to 540 of 1180
- Sep 2007
- 211
January 21st, 2008 09:18 PM #531mga bossing! tanong ko lang kung ano ba talaga ang tire pressure nang alterra? nakalagay kasi sa pinto sa side 26 to 29 PSI daw pero sa tingin ko parang malambot yung goma. heto pa po lagi ako nawawalan nang busina lagi nasusunog ang fuse pinalitan ko kasi nang fiamm yung alterra. ano po kaya ito? thank you mga bossing!
- Oct 2007
- 83
January 22nd, 2008 12:30 AM #532
January 22nd, 2008 06:49 PM #533
January 22nd, 2008 08:45 PM #534
Ano ba yung sinasabi ng mga mekaniko ng Isuzu na kumbinasyon ng timing chain at timing gear yung makina ng Alterra at Dmax?
- Sep 2007
- 211
January 22nd, 2008 10:27 PM #535
Tsikot Member Rank 4
- Jan 2007
- 2,326
January 23rd, 2008 05:09 PM #536Won't that defeat the purpose of a fuse which is to break the electrical connection in case of short-circuit? If you increase the amerage, it could lead to dangerous condition where despite a short, hindi siya pumutok at, in a worst case, masunog ang electrical mo!!Minsan kung ang design ang may problem, tinataasan nga yan. Pero not with that magnitude.
January 23rd, 2008 08:01 PM #537
- Jan 2007
- 2,326
January 24th, 2008 03:44 PM #538Hindi ko po opinion yun. Definition po yun ng FUSE. From wikipedia:
In electronics and electrical engineering a fuse, short for 'fusible link', is a type of overcurrent protection device. Its essential component is a metal wire or strip that melts when too much current flows. When the metal strip melts, it opens the circuit of which it's a part, and so protects the circuit from excessive current.
Fuses (and other overcurrent devices) are an essential part of a power distribution system to prevent fire or damage. When too much current flows through a wire, it may overheat and be damaged, or even start a fire. Wiring regulations give the maximum rating of a fuse for protection of a particular circuit. Local authorities will incorporate national wiring regulations as part of law. Fuses are selected to allow passage of normal currents, but to quickly interrupt a short circuit or overload condition.
Hindi ko naman sinasabing masama in all cases kasi puwede naman re-wire ang buong circuit. Hindi din ibig sabihin dahil madami ng nagpalit ay OK na dahil iba iba naman ang allowances ng mga circuit. Sinasabi ko lang ay PUWEDENG maging delikado depende sa sitwasyon at sa panahon lalo kung hindi na assess ang buong circuit at nagpalit lang ng fuse. Maaaring ilang taon nga ang lumipas bago magka-epekto ito eh. Kung malaking dealer nga kayo, sana hindi ninyo ginagawa yung huli kasi palagay ko madaming ibang gumagawa nun.
January 26th, 2008 01:06 AM #539
Ask ko lang altera owner's, d b matipid po ang altera? anybody got their actual FC's??? tnx
- Sep 2007
- 211
January 26th, 2008 01:53 AM #540
