Page 8 of 9 FirstFirst ... 456789 LastLast
Results 71 to 80 of 83
    #71
    Alin mas ok KYB N fluid or gas Type
    #72
    [IMG]2012-03-13 13.55.40.jpg [/IMG]
    [IMG] 2012-03-13 13.56.00.jpg[/IMG]
    553177 - Front (but much longer of 5cm to original Shock)
    553108 - Back ( same size)
    Jan 2018
    #73
    Hi Ask ko lang po sana.
    May effect po ba sa sasakyan pag yun isang side ng leaf spring nadurog yun spacer between the two leaves or ok lang kahit wala?
    Ito yun may spacer sa gitna ng leaf sa driver side.
    Click image for larger version.
    Ito yun sa kabila na nadurog na ata from wear and tear.
    3+yrs old pa lang yun sasakyan namin.
    Jul 2013
    #74
    Quote Originally Posted by ferddie View Post
    Baka umingay yung suspension since metal to metal sya.
    Although may times na di mo pansin since naka-AC naman palagi
    Jul 2019
    #75
    Quote Originally Posted by celi_bate View Post
    Just got back from banawe, have an isuzu xuvi 2003, changed the rear shocks becuz the stock ones were leaking. Got the KYB gas shock absorbers (they cost me 1,400 each). Also got the rear lifted using hangers which cost me 1800 for both including labor. Just so i dont forget (and because no one here really puts up the price) changed my front tires at michelin the fort, they cost 5400 each. Changed my alarm din in banawe which cost 2000 (the stock alarm is loud, annoying and rattles my wife everytime i set it on). The only thing i think that helped with making the ride smoother was i had nitrogen placed in my tires instead of air at michelin. It costs 100 per tire and i can go back if ever the tire gets soft for free. There they recommended all tires at 30psi, and it myt be psychological but i feel there is a slight improvement. Got HIDs din na china lang, they cost me 5k for both, its been about 2 years na and so far so good.
    Yes, I can confirm that filling nitrogen on your tires does help the dampening effect. Maski +5 psi pa yung kinarga sa tires ko, ok pa rin ang 40psi kaya di ko na pinabawasan kasi malambot pa rin sya.
    Jan 2018
    #76
    pero in terms of performance wala naman problem? or long term effects?
    Jul 2013
    #77
    performance wala... pero minsan nakakainis yung ingay, especialy kapag kaka-lusong sa baha - as in halos nakaka-hiya na
    long term effects? how long? - wala akong naaalalang passenger jeep/bus na may spacer sa leaf spring.
    Jul 2013
    #78
    *easy fix... lagyan mo ng rubber
    #79
    papano po?
    Weird how that doesnt have shackles like those of newer pickups...
Crosswind Rear Suspension
