Page 20 of 21 FirstFirst ... 10161718192021 LastLast
Results 191 to 200 of 204
    #191
    I just called jayson's for a quote for a timing belt for 4JG2-turbo. I was informed that there are 2 kinds - round and flat. Hmmm.... hassle naman if I have to take it apart pa first before buying the part. Any ideas on how to check or what to do?
    Thanks
    May 2011
    #192
    hi guys do anyone have for sale piston with connecting rod for 4jg2 turbo subic type or do anyone knows how much is that cause????pls pm me up tnx u guys
    May 2004
    #193
    Quote Originally Posted by edtf View Post
    Thanks
    nung nagpalit yung barkada ko sa subic trooper nya isang klase lang available namin na timing belt dun. flat sya. same ng 4ja1. although replacement lang tinda namin. so far puro yun naman ang kinukuha samin ng mga bumibile. hth.
    btw, flat sya.
    #194
    Quote Originally Posted by niwde11 View Post
    btw, flat sya.
    thanks sa reply! Mukhang Gates nalang nga kukunin ko laki ng difference and at the same time kilala rin naman ang gates.
    #195
    Quote Originally Posted by mintoy View Post
    new trooper owner rin ako.
    just replaced the timing belt. got the original isuzu belt for 2.5k in pasay. replacement belt cost 900. i also got 2 tensioner bearings and original oil seal for the crank shaft. i spent a total of 5k. labor was 2.5k sa PERCC in balintawak.
    Sir Mintoy, Did you change the rear crank shaft oil seal too? I heard you have to take the engine apart to get to the rear crank shaft oil seal
    Jun 2004
    #196
    no, i didn't. that would be an entirely new expense.
    Aug 2008
    #197
    Quote Originally Posted by nap123 View Post
    Hi Val,
    Kung EFI na yan bighorn mo pwede mong kabitan ng performance chip see this link http://cgi.ebay.ph/Performance-Chip-...3A1%7C294%3A50
    Sir,
    How will I know if EFI un engine ko?
    Gustu ko sana bumili ng performance chip eh.. Un pala link regarding chip dead na. any other link?
    So far ok naman ang Big horn ko. sa performace lakas humatak ng makina, matulin din kashit 4gj2 engine. wala naman major na sakit ng ulo except nun magpalit lang ako ng turbo which cost me ~25k.
    Thanks,
    Val
    Feb 2005
    #198
    Quote Originally Posted by val_c4 View Post
    Thanks,
    Val
    Val, you said it yourself, maayos naman tumakbo, di ba? Unless you drive mostly on clear highways, why need to spend for a performance chip? Dagdag gastos pa.
    If you have the extra money for such, best to save for a rainy day. My 2 cents.
    #199
    Quote Originally Posted by Benzmizer View Post
    Take it from sir Benz. Mayaman yan pero he still thinks it's not worth it ha.
    Aug 2008
    #200
    sir,
    thanks for the advise.. sinunud ko na.. i'm back... me problem na nman ako...huuhuh
    muka me problem na naman turbo ko...
    Hingi po ako ng advise. un bighorn ko pag dinidiinan un gas pedal at nasa peak na meron tumutuniog na mahina at matining na prang yero or prang grinding pag wala na sa peak wala na din ung tunog. anu po kya ito?
    Sabi ng mekaniko ko is yung turbo daw un, papalitan na...if turbo nga ito, anu kaya ang naging cost nito?
    thanks,
    val
4jg2  tdic engine
