Page 17 of 21 FirstFirst ... 7131415161718192021 LastLast
Results 161 to 170 of 204
    Feb 2005
    #161
    Need help for all Trooper Expert...
    Problem on Overdrive pag long run na di na nag shift sa 4th gear
    pero pag malapitan lang takbo nag shift naman.. Hmm, what is your speed when you notice that the tranny does not shift to 4th? What is the RPM reading?
    Already done change Tanny fluid ang cleaning of Filter..
    Any shop na malapit in laguna area? Is the "shop" you are referring to is other than an ISUZU dealer? Why not bring it to an ISUZU dealer and get there evaluation based on test drive or use of Tech 2? Baka lang kasi mas mapalakit ka pa ng gastos if a generic shop assess your Trooper (without using a Tech 3 gadget) and make a wrong evaluation....
    My 2˘
    Jan 2008
    #162
    100km/hr at 3000rpm..
    ako lang po nag change oil sir
    Trooper subic lang sir..
    baka mapamahal pag sa isuzu sir eh
    salamat
    Feb 2005
    #163
    Quote Originally Posted by winr01 View Post
    ako lang po nag change oil sir. Trooper subic lang sir. baka mapamahal pag sa isuzu sir eh.
    The likelihood of a faulty OD switch is slim. Sad to say but it MIGHT be the transmission already. I have a friend who similarly encountered a case like yours... It wasn't the OD switch but the tranny at fault.
    If you "fear" having the CASA check the tranny, go have it checked by a knowledgeable and trusted mechnic. And hope you do this ASAP.
    Jan 2008
    #164
    ganun po ba sir..
    wala na ba pwede i check like mga sensors..
    san po ba meron good mechanic dito?laguna area po ako
    Aug 2008
    #165
    sirs,
    mraming salamat pong muli sa inyong mga replies. I am really going to the right direction.
    for now, papaitan nmin un bumper to make it loo better. kapag ntapos ko ito i will try to post some pics.
    sir s_quilicot,
    thanks re reminder. sikapin ko di na maulit.. napapsarap kasi minsan sa reply.
    oo nga po pla, is there anything special about gear oils, transmission oils.
    ano pa po ba mga bagay na dapat ko mpangalgaan at tuunan ng pansin
    thanks,
    val
    Feb 2005
    #166
    Quote Originally Posted by val_c4 View Post
    My Trooper currently has 91,xxx in its clock and has not given me any headache since I got it new last 2005. Concerning your question gear oil, transmission oil, etc., just make sure that you drain these liquids (including coolant) every 40,000 kms. Personally, I would not insist that you use top gun oil brands.... those sold in gas stations would do.
    Aug 2008
    #167
    Good morning!
    katatapos lang ng pag ayos ng trooper ko. I will post pictures later.
    I would like to inquire saan ba mkakabili ng accesories ng trooper. san ba un walco sa banaue. bka me alam din kayu na mura na magandang bilihan.
    anu pa ba ang puwede ko gawin pra mas lumakas ang hatak and less fuel consumption. i'm planning to buy the kit na nakita ko nka adverise dito sa website na ito.
    http://cgi.ebay.ph/Performance-Chip-...3A1%7C294%3A50
    saan ko ba puwede ipakabit yan. any instruction how and where to install it? can i buy it directly so mas mabilis. baka me alam kayu dealer nyan sa pinas.
    pahabol mga bossing!!
    saan po ba mkakuha ng manual ng bighorn?
    di ngayun lang din kasi ako mag mamaneho ng automatic and gustu ko ma maximize performance and pat na din matutu sa kabuuan nito.
    Thanks again!!!
    Sep 2009
    #168
    good morning mga sir...
    new lang ako dito sa site..
    advice naman po dyan.hard start trooper ko kapag hindi nagagamit nang isang araw/early morning na malamig...thanks po...
    #169
    Quote Originally Posted by ivan21 View Post
    Check your fuel system for air leaks. Gas tank to filter to pump.
    Sep 2009
    #170
    thanks sir 4jgtootsie sa mabilis na reply.
    tried to switch battery ng starex namin...umandar na siya.
    hehe...palitin na pala battery ko...
    mabuhay mga tsikot members!
    lalo na mga isuzu owners!haha
4jg2  tdic engine
