Page 127 of 170 FirstFirst ... 2777117123124125126127128129130131137 ... LastLast
Results 1,261 to 1,270 of 1696
    Apr 2011
    #1261
    Even the engine treatment worth 800+ should not be there
    Jan 2014
    #1262
    Undercoating(this isnt listed in the maintenance checklist)
    Spark plugs(originals were good for 60k)
    Coolant(if you checked, it prolly didnt need additional coolant)
    Brakestop squeel(redundant)
    8000 peso hold up
    Quote Originally Posted by airolynx View Post
    I agree with both. Grabeng raket naman yan.
    8000 peso hold up
    Jan 2009
    #1263
    Quote Originally Posted by KingReyes View Post
    Grabe almost 9k ++ ang nadagdag
    #1264
    Hi Questions, Accent MT Gas 2013 owner:
    >Talagang 10km ang replacement ng OEM NGK spark plug? Sabi sa ibang threads pwede more than 10Km or up to 60km if NGK iridium. Any one sumubok na di nagpalit ng spark plug after 10km? or pumapayag ba ang casa nyo?
    > yung aircon cleaner, every 20km ba dapat or check up lang dapat?
    > yung oil filter or top up, kelangan ba after 5k kapag fully synthetic? may nabasa kasi ako, recommended for old engine only.
    Iba kasi ang nsa Owners Manual ng 2013 accent compared sa PMS ng Casa.
    Thanks Guys.
    Thanks Guys.
    [QUOTE=baranvincent;2481597]Hi Questions, Accent MT Gas 2013 owner:
    It's replace if needed. If they will do this...you want to see the old plugs....normally if its clean...its not necessary to replace. Simple lng yan. Ask to be there before they remove your plugs. Some shops show ugly plugs from other vehicles. 30k na sasakyan ko hyundai hasnt replaced any spark plugs.
    Its part of maintenance. Nadudumihan talaga parts ng ac ng car. You can DIY. So you can skip this. I dont remember having this on my 20k pms.
    Oil filter change is not necessary if its original hyundai filters. BUT I think hyundai ph requires engine oil filter change every 5000 km. When you change your filter....it needs an oil top off.
    Jan 2014
    #1266
    PMS of my SF3 done today. These are what I availed of for 10K KMs:
    7 liters FS oil
    Oil filter
    Air filter
    Pollen filter
    2 bottles brake cleaner
    Fuel system cleaner
    Oil system cleaner
    Drain plug washer
    Miscellaneous fee
    And I did not avail of these:
    AC cleaner
    Brake paste
    Engine treatment
    WS shampoo
    Complete wash
    Total was 10,141.87 PHP. Next time I'll also have the fuel system cleaner and oil system cleaner removed.
    7 liters FS oil
    Oil filter
    Air filter
    Pollen filter
    Fuel system cleaner
    Oil system cleaner
    Drain plug washer
    Miscellaneous fee
    AC cleaner
    Brake paste
    Engine treatment
    WS shampoo
    Complete wash
    #1267
    Just had my 40k PMS for my 2014 Accent diesel hatch in Hyundai Las Piñas. Total charges was P12,500.
    Top up 1 lit FS oil
    Changed coolant
    Changed transmission oil
    Changed oil filter
    Changed fuel filter & water sensor
    Cleaned brakes
    Rotated tires
    Changed air con filter
    Changed air filter
    Brake cleaner
    Fuel system treatment (took home for diy)
    Silicon oil
    Engine detailing
    Full body wash & interior cleaning.
    Apr 2011
    #1268
    Top up 1 lit FS oil
    Changed coolant
    Changed oil filter
    Cleaned brakes
    Rotated tires
    Changed air filter
    Brake cleaner
    Silicon oil
    Engine detailing
    Not bad sir. It will reach around 15k if you include 5 more liters of fully synthetic oil. Halos similar lang sila ng maintenance ng Honda City in terms of cost. Para saan sir yung Silicon Oil?
    #1269
    This was a major PMS. I think they used it in cleaning the engine. Good thing my brake pads & belts are still ok.
    #1270
    ingat sa PMS costings ng hyundai. lalo na yung sa may shaw-mandaluyong. yung sirang ng ibang hyundai cars ginagawa doon, papalabasin nila na iyon ang sira ng sasakyan mo. grabe raket lalo na yung baklang dealer doon,, kung nandoon pa sya.
Hyundai PMS
