Results 1,871 to 1,880 of 4790
October 10th, 2013 07:44 AM #1871
Hi fellow Accent HB owners. I have a problem with my 800 km HB AT usually intermittent lang nangyayari at pag matagal na nakapark tapos start mo.. Pag nasa start na yung ignition hindi sya nagstart and usually around 5 and longest ay 10 seconds bago bigla mag crank.. Hindi siya hard starting pero hindi lang nagcrank agad.. Mukhang hindi naman weak battery kasi wala naman ako naririnig na nagcacrank.. Better pa check ko na lang since malapit na rin ang 1000Km checkup. something wrong with the electronics or starter?
October 10th, 2013 08:48 AM #1872
October 10th, 2013 08:50 AM #1873
Sir check niyo baka Hindi masyado naka press yun clutch or Baka nakahalang yun matting niyo sa clutch.
- Jul 2013
- 19
October 10th, 2013 12:07 PM #1875kakakuha ko palang ng clean blue accent at ko kahapon. parang santa fe ang acceleration. sarap i drive.
- Sep 2013
- 168
October 10th, 2013 12:14 PM #1876Not sure kung ganito rin ang hitsura ng indicator lamp sa Accent HB. Pero if it bypasses the starter circuit while activated, then the engineers at Hyundai did a pretty good job. It's normal and should be the correct process IMO. Diesel yan eh,
- Jun 2013
- 38
October 10th, 2013 05:20 PM #1877*kompressor yup ganyan nga but nasa lower left ang glow plug indicator.ng hatchback.
- Sep 2013
- 10
October 10th, 2013 07:45 PM #1878
October 10th, 2013 07:45 PM #1879
Yes the glow plug indicator light is off when it happend. 2 seconds lang usually on yung light indicator before it turns off. The longest non cranking I recorded was around 10 seconds before the engine crank to life. Will have it check na lang siguro. It could be the bypass circuit on the glowplug having problems or defective. Akala nya on pa yung glow plug but off na pala.. Will update this post on any findings..
- May 2013
- 32
October 10th, 2013 11:11 PM #1880sir i think we have the same problem, long time idle-engine off, it won't start on the first try. Sometimes it took me 3 times. Upon switching to start, i've just heard a click sound no crank at all. I'm suspecting trouble on our starter solenoid. I'm nearing my 5k pms and have it check for warranty claim. I'll post update after my car check-up & maintenance service.
