Results 981 to 990 of 1294
March 26th, 2012 09:53 AM #981
- Jan 2009
- 14
March 26th, 2012 10:08 AM #982Sir magkano score niyo sa Mags and tires niyo? bkt parang ang liit niya para sa isang 16'?
Mukhang maliit siguro dahil sa tires kasi nagkamali yung pinagbilhan ko dapat 195/50 nkakabit naging 205/45 hindi ko na sinoli. Anyway papalitan ko agad to ng 195/50. Benta ko na lang 'tong nakakabit na tires.
- Jan 2012
- 10
March 26th, 2012 02:23 PM #983
- Nov 2011
- 24
March 28th, 2012 01:12 PM #984Ano nga pala specs ng gulong ng Accent? what to consider pag magpalit ng mags?
- Jul 2009
- 3,604
March 28th, 2012 02:34 PM #9851. Offset & Lug Pattern - Ideally have the same offset para hindi masyadong pasok or labas yung rims (will encounter rubbing issues while steering). Lug pattern and distance between lugnuts should be the same para fit.
2. Rim width - Masyadong makapal - same issue as above while steering lalo kapag sinagad yung manibela.
3. Overall diameter - Diameter of the stock rim + tire should ideally be the same as the new rim + tire combination. Meaning, if you increase the rim size by 1" diameter, the new tire must be 1" thinner at the sidewall. Switching to lower profile rims will have negative effects on ride comfort. Using a different combination of tire/rim sizes may result in suspension issues as well as inaccurate speedometer readings.
4. Rim + Tire weight - the heavier the total rim + tire combination compared to stock, the more fuel the car will consume as more effort is needed to overcome the inertia of a heavier object.
5. Cost of tire - Larger rim diameters will require more expensive tires. Ang tires for a 13-16" rim can be lower than 5k / tire, but same tire for an 18" rim will cost nearer to 8-10k / tire.Last edited by mda; March 28th, 2012 at 02:36 PM.
- Nov 2011
- 24
- Feb 2012
- 13
March 28th, 2012 03:18 PM #987mga sirs, help naman po sa meaning ng I.C.E, related po ba sa sound set up? and pwede din maka hingi ng advice kung gusto ko mag set up ng sounds, hindi naman pang entry level po. What to buy and corresponding prices. Pls do add the brand name thanks.
March 28th, 2012 03:24 PM #988
ICE = In Car Entertainment. Even a stash of FHM in the back seat qualifies as ICE. hehe
Seriously. Try the folks at Kotseaudioclub.com . They have been a great help to me even now that I'm still a newbie to in car entertainment.
- Jan 2009
- 14
March 28th, 2012 03:59 PM #989Question lang mga Sirs, totoo ba n hindi maganda or ok ang 195/50 na gulong sa nabili ko mags na 16x7?
Sabi kasi nung napagbilhan ko nung magpapalit ako from 205/45 eh hindi match daw uusli ng konti ang rim kasi mas manipis yung width ng gulong. Although kapag nagcompute naman ng overall diameter konting konti lang ang pinagkaiba ng 205/45 sa 195/50 mga 10.5mm. Napansin ko din medyo nakadungaw ng konting konti ang gulong sa fender / body.
Gusto ko sana yung recommended wheel specs ng accent na 195/50 para sa warranty ng suspension.
TIA
- Jul 2009
- 3,604
March 28th, 2012 04:19 PM #990What is the stock size and offset of your existing rims? Ano offset ng bago?
See my post above regarding the Offset and Rim Width. I think this applies to you.
Kung nagpalit ka ng rims, most likely wala na ang warranty ng suspension, even if the rims came stock from another vehicle of the same model (i.e. yung rims ng Accent Blue ilalagay dun sa 1.4). AFAIK this applies for Honda and Toyota. Not sure about Hyundai.
Tesla Philippines
