Page 712 of 808 FirstFirst ... 612662702708709710711712713714715716722762 ... LastLast
Results 7,111 to 7,120 of 8072
    #7111
    May nakapag retrofit na ba ng 3 point seatbelt sa inyo? My sis is shopping for a car seat and most car seats available are for cars with 3 point seatbelts.
    #7112
    Quote Originally Posted by spat View Post
    Boss, try mong pahiran ng armor all or sprayhan ng silicon oil yung goma sa may sliding door.
    Sa amin inisprayhan ko, bumilis buksan ang sliding door. Para kasing dumidikit yung goma sa sliding door mismo e.
    Thanks sir, na lubricate naman sya ng maayos pero may konting kalog na kasi sa lubak. Also yung isang side may mild accident with a tricycle kaya wala sa alignment.
    Has anyone replaced their valve stem seals already?
    #7113
    May option din sir for 2 point seatbelts for brands like Chicco. I vaguely remember having used their car seat on the 2nd row.
    #7114
    I have the same experience of using just a lap belt (2-point seatbelt) on a Chicco car seat....
    33.2K _/_/_/_/_/_/_/_/_/_/
    #7115
    The way they demonstrated the child seat to us, it looks like it will work even on a 2 pt seatbelt
    #7116
    Thanks guys for your opinions.
    Apr 2012
    #7117
    What do you think is the culprit?
    Pag nag 60 kmh-100kmh na ako may vibration sa steering wheel
    Tire balancing lang ba or check alignment na?
    Sent from my LG-H818 using Tapatalk
    Nov 2007
    #7118
    Happened to me before. Balance muna then alignment done. Both needed correction
    #7119
    First, have all suspension bits checked including the big bushing of the control arms. Most suspension shops don't check that because the rack ends and stab links are always the first suspects. Then have the tires balanced. Lastly have the alignment checked.
    Happened to me before. Replaced the usual stab links and rack ends, had the tires balanced and aligned. A few hundred kms later may alignment wear na yung bagong tires. Pag check sa big bushing ang laki na pala ng play.
    Apr 2012
    #7120
    Quote Originally Posted by JJB View Post
    Thanks! Will drop by Servitek tomorrow. Or sa Minerva na lang? What do you think
2008 Hyundai Starex (Gen. 4)
