Page 657 of 808 FirstFirst ... 557607647653654655656657658659660661667707757 ... LastLast
Results 6,561 to 6,570 of 8072
    Apr 2012
    #6561
    What's the solution for sticky sliding door?
    Sent from my LG-H818 using Tapatalk
    Jun 2012
    #6562
    Hancars is using this pag pms. Spray sa 3 na railings
    #6563
    Quote Originally Posted by dct View Post
    that is just the cheaper WD40 copy.
    Jun 2012
    #6564
    So pwede na ang wd40?
    #6565
    Unlock(slightly open) the sliding door using the door handle...... And then open it fully by holding the edge of the door and pulling it out-sideways....
    #6566
    i would not recommend using wd40 or any oil on the rubber gasket of the doors. Oil can cause the rubber to deteriorate.
    On the sliding door rails and also on ordinary door hinges i suggest silicone spray lubricant. On the door rubber gaskets just regular cleaning with soap and water. Clean both the rubber gaskets and the area where the gasket seals.
    #6567
    I just wet it, or wipe it with a wet cloth...
    The stickiness wears out after a while....
    29.9K _/_/_/_/_/_/_/_/_/_/
    Aug 2012
    #6568
    Most people think of WD40 as the usual WD40 Multi-purpose Lubricant. WD40 has multiple products for different materials. They have Contact Cleaner, Engine Degreaser, Silicone Lubricant, White Lithium Grease, etc.
    Sent from my D5833 using Tapatalk
    #6569
    Quote Originally Posted by darkpalosx View Post
    2010 model matic 80k sa odo.pansin ko lang na hirap humatak maski sa hway yung van namin pag oovertake,parang wala na yung dating pagapak m sa accelerator hatak kaagad.ano kaya problem nito?
    sir nawalan din dati power GS ko matic 09, dami kelangan check, atf,fuel filter etc,, pro sakin ang prob pala eh turbo actuator not working sira na diapram, kaya check mo sir ,ganito silipin mo ang turbo actuator na parang turumpo cya sir sa ibabaw ng turbo,pa start mo dapat makita mo na itutulak ng actuator ang lever pababa hangang stopper niya, tapos pa rev mo paulit ulit dapat nag tataas baba cya,,pag hinde o mahina pa check mo na sa expert ang actuator,baka may butas na diapram,kung meron ka hand vacuum pede yun pang test sa actuator,,pati turbo solinoid pa check mo rin,, sana makatulong,,
    Nov 2007
    #6570
    Anong alarm ang pwede i-upgrade sa units natin? Di na gumagana ang remote din kse.
    Isa pa napansin ko na halos lahat ng door sensor ay sira na. Interior lights don't light up anymore pag open ng sliding doors and passenger door.
2008 Hyundai Starex (Gen. 4)
