Page 635 of 808 FirstFirst ... 535585625631632633634635636637638639645685735 ... LastLast
Results 6,341 to 6,350 of 8072
    #6341
    my guesses:
    1. in-efficient fans.
    a. perhaps it is time to replace the electric aux fans.
    b. time to re-charge the direct-drive clutch fan material (silicone?)
    2. clogged radiator.
    Thanks on this. Will have these checked siguro next week.
    Dami naman issue netong GS namin. haha. Good luck pa sa 'warranty' ni HARI.
    [QUOTE=dr. d;2612274]- - - - - - - - - - - - - - - - - - - - - -
    #6342
    Guys need help po.. My GS TCI m/T is showing some problems.. Nag sticky ang clutch nya pag natratraffic and naka idle ang engine for a time.. Pero pag. Ok naman ang byahe no problem... Any suggestions po or solutions for this.. 35k palang po milage nya.. And ako lang gumagamit di naman po ako clutch driver.. Ok pa humatak no drag or slide... Pa help po.. thanks
    #6343
    Quote Originally Posted by rosevb05 View Post
    please explain... what is "sticky clutch" ?
    #6344
    sir yung pag inapakan mo young clutch pedal tumitigas sya and medyo may delay ang pag angat nya sa normal position.. na experience ko po ito pag natratraffic and naka idle ang sasakyan for a time.. pero pag napahinga sya normal naman ang operation
    #6345
    Click image for larger version.
    sir to po yung post sa kabilang forum.. same problem sakin
    #6346
    this is new to me... hydraulic clutches should be foolproof..
    let's see..
    check clutch pedal free play, po.
    then there's the clutch assembly inside the housing.. deformed? perished bearing? opening her up is the only solution to me..
    perhaps someones out there can provide experiential solution.
    let's see..
    #6347
    how come if im not in traffic and the van is moving.. the clutch pedal is operating normally. this problem will start when the van is idle for a time ( i think 15mins ) and im getting stuck in traffic.. and if the problem worsen ill just shut off the engine and let it cool off for an hour.. then it will operate again normally.
    #6348
    is the new starex clutch still the traditional one? or is it now also power-assisted?
    if traditional, i'd probably discard the temperature angle. the problem sounds mechanical.
    let's see... may tumutukod kaya sa pidal?... is the master cylinder ok? what about the slave cylinder?.. if these are all ok....
    i am afraid you might have to open up the transmission housing..
    if, however, your trans is cable-operated, i suggest you replace the cable.
    #6349
    sir my GS is a 2012 TCI M/T fluid type sir.. not cable operated. wala naman pong tumutukod sa pedal..
    #6350
    paging other ideas!
    kung ako, pabubuksan ko na ang transmission housing..
    paging other ideas!
2008 Hyundai Starex (Gen. 4)
