Page 489 of 808 FirstFirst ... 389439479485486487488489490491492493499539589 ... LastLast
Results 4,881 to 4,890 of 8072
    #4881
    i was looking at the GRX engine layout.. and the intake manifold is quite different to the GS engine intake manifold.. unfortunately posting pics here still confuses me. heheh..
    #4882
    Done! changed oil kanina 1pm using motul specific, then went to ace to look for materials and buy a cutting disk for my grinder.
    yup, 10 minutes is more than enough time for the install if you have the blanking plate on hand. it took me another ~45 minutes to fabrictae the plate using the gasket as a pattern. i used a Yale door lock hasp for the plate, cost P109. wala ako makita na steel plate sa ace but saw some materials there that can be used - a painter's scraper, a mason's trowel, and the Yale hasp. the hasp was the thickest of the 3. meron pa nga stainless steel hasp pero nag-alangan ako baka hindi kaya ng drill bits ko sa bahay.
    i only ran the gs in the garage, 4pm na ko natapos and it was raining. walang CEL. i will try tomorrow on the road.
    next one will be the sorento by tomorrow afternoon.
    #4883
    Iyan si bro,yebo..... DIY....
    Where did you blank it bro....?
    How is it today???
    #4884
    dun sa naka circle sa post ni IMm29.
    balak ko sana dun sa inlet ng egr kaso madami aalisin, e kung mag cel baklas na naman so change of plans to what works already.
    ok naman kanina, parang lumakas ang hatak ng konti, placebo effect hehehe! pero that could also be the oil at bagong palit din kahapon, first time to use motul.
    di ko magawa sorento, ginamit ni misis hangang ngayon wala pa.
    Oct 2013
    #4885
    hi to all gs owner, after blanking my egr last month,i have successfully installed my GREEDY oil catch can last nit, the occ, hoses, clamps and bracket came from zix 888 but the installation was DIY.
    #4886
    dun sa naka circle sa post ni IMm29. balak ko sana dun sa inlet ng egr kaso madami aalisin, e kung mag cel baklas na naman so change of plans to what works already. ok naman kanina, parang lumakas ang hatak ng konti, placebo effect hehehe! pero that could also be the oil at bagong palit din kahapon, first time to use motul. di ko magawa sorento, ginamit ni misis hangang ngayon wala pa.
    Nice bro. Diy-er talaga! Destroy yung D ko kaya pass ako sa DIY hehe!
    I was telling Zix 888 that feeling ko placebo lang at first, kasi parang gumaan. Then i started flogging it, immediate yung response! I even floored it sa driveway ng rcbc, pero by accident. Burnout, pwede ipalo yung pwet. And all this with 10 month old oil due for replacement.
    Posted using TocinoTalk
    Apr 2012
    #4887
    Ppa blank na ako nxt month. Napansin ko kahapon sa MOa iba engine layout ng Gs ko kesa dun sa display. Dun sa part na naka circle parang iba nakalagay sa akin dyan. May parang plastic dun na may screw na may siemens na brand. Btw grey market unit akn
    Sent from my SGH-I717R using Tsikot Car Forums mobile app
    #4888
    lowering down the air intake temp is almost the same as putting a bit bigger intercooler bro.
    btw just finished some plates for our fellow tsikoteers
    #4889
    Long drive galore! Sarap ilaro sa SLEX kagabi.
    #4890
    mas maganda effect ng blanking sa inyo(GS). on other engines, at idle and low rpms lang commanded open ang egr valve, kaya after blanking, sa low rpm talaga maramdaman, but sa gS, commanded open ang valve by ecu at different ranges ng rpm, kaya ang effect will be felt not only on low rpms
2008 Hyundai Starex (Gen. 4)
