Results 6,641 to 6,650 of 8072
September 29th, 2016 01:00 PM #6641
kaya ako basta diesel ever since lumabas ang euro4 di na ako nagfi-fill up ng euro2. the worst of the big 3 is petron diesel (mausok) followed by shell (low power, mabilis maubos). pag walang-wala na talaga naghahanap ako ng caltex. even now that petron say they are euro4 medyo mausok pa din ang regular diesel nila. yung dieselMax ok lang kaso mahal naman.
- Oct 2015
- 1,054
September 29th, 2016 01:37 PM #6642I think uusok pa rin talaga at load bro. Sa Europe may nakita akong Euro 5 engines na mausok. Ang hirap linisin ng egr ng Euro 4 GS, masikip yung side na dinadaanan ng egr. I wonder how the early examples of GS with Euro 5 engines are doing. 2011 yung amin pero meron na rin lumabas Euro 5 the next year. Matagal tagal din nakagamit mga 2012 models with Euro 5 engines ng Euro 2 diesel.
- Apr 2012
- 3,469
September 29th, 2016 03:49 PM #6643
- Jun 2012
- 4,447
September 29th, 2016 04:31 PM #6644No need clean the egr pag euro 5 di ba? Dahil may dpf. Tama ba?
Sent from my SM-G920F using Tapatalk
September 29th, 2016 05:10 PM #6645
afaik need pa din boss. hiwalay function nun. yung egr recirculates the exhaust back to the intake manifold to lower engine combustion temp which in turn lowers NOx production. yung dpf nasa exhaust pipe mismo, it catches the sulfur soot from the exhaust. nagre-regenerate siya, burning the soot by injecting diesel into the dpf. yung dpf is positioned after the egr inlet e.
- Oct 2015
- 1,054
September 29th, 2016 05:15 PM #6646Forgot to mention sa casa ginawa yung egr cleaning, went back to Hyundai Cainta. No choice, sila lang kasi malapit sa amin. They did mention the Euro 5 engines's egr layout was easier to clean. We did the catalytic converter and exhaust cleaning at home. Ganda ng takbo after.
Kelangan pa din linisin sir if you haven't blanked it. Specially if it spent a lot of kms on Euro 2 fuel we had prior to this year. DPF simply catches all the soot so it doesn't go out the tail pipe. It is downstream of the egr. Will get back to you re: brake pads. I'm testing a new set right now. We also replaced the front rotors last week.
- Jun 2012
- 4,447
September 29th, 2016 05:21 PM #6647
- Oct 2015
- 1,054
September 29th, 2016 05:34 PM #664857 Tkms na din natakbo sir, also mahina talaga parts ng Hyundai compared to Japanese makes. We also had a Tucson before, replaced front and rear rotors at 45 Tkms. Pwede pa naman gamitin yung rotors pero lampas na sa recommended wear limit which is 2mm. Mahina na kumagat.
- Jun 2012
- 4,447
September 29th, 2016 05:39 PM #6649
October 2nd, 2016 10:17 AM #6650
San ok magpatingin ng A/C ng GS? Nabilad kahapon, matagal lumamig.
Sent from my Motorola Startac
