Page 636 of 808 FirstFirst ... 536586626632633634635636637638639640646686736 ... LastLast
Results 6,351 to 6,360 of 8072
    #6351
    yes sir.. pa check ko .. thanks sir for your replies..very much appreciated
    Jun 2008
    #6352
    sir paki check ang drive belt & pulley ng alternator baka di umikot ng maayos. nasa rear ng alternator ang vacuum pump para sa hydro-vac ng preno. suspetsa ko dyan ang problema. HTH
    sagot ko po para sa brake problem.
    Jun 2008
    #6353
    paging other ideas!
    kung ako, pabubuksan ko na ang transmission housing..
    paging other ideas!
    ask ka po sa mga starex owners., starex club ng team hyundai philippines. something wrong sa unit mo. i don't believe that the temperature under hood is the culprit.
    #6354
    Quote Originally Posted by weisshorn View Post
    ok sir pero sa kabilang forum po.. parang less than ten kaming nakaka experience nung same problem..
    thanks sir
    thanks sir
    #6355
    eto po yung post nila
    Click image for larger version.
Name:	Screen Shot 2015-09-26 at 6.59.39 PM.jpg
Name:	Screen Shot 2015-09-26 at 6.59.43 PM.jpg
Name:	Screen Shot 2015-09-26 at 7.00.00 PM.jpg
Name:	Screen Shot 2015-09-26 at 7.00.12 PM.jpg
    #6356
    Ooh man... Is this sticky clutch problem only experienced on the vgt variant????
    Our company ride is tci and our driver has not complained anything similar to this so far....
    #6357
    Quote Originally Posted by skyflakes View Post
    yan ang na encounter namin noon... kung gusto mo sir pa check mo muna yung hydrovac(brake booster) nakakalas naman yan..mas maganda sir dun sa may special tools o may pangkalas talaga.
    ah talaga, meron tumitingin ng hydrovac?,,, sir may alam ka ba kung saan ? taga Las Pinas area ko,, salamat
    #6358
    Quote Originally Posted by SkyFlakes88 View Post
    Sir yun mga brake po kasi over time dumudumi sa loob lalo pag summer time tapos pag rainy season na at nadaan nyo sa baha yan nag clo-clog na yun mga residue sa preno kaya nag stuck up yan. You need to get your brakes cleaned po. Bubuksan po lahat preno at lilinisin to free up all the moving parts inside pati palitan kung may dapat palitan na mga rubber parts at yun mga pads if needed.
    sir bago na lahat ng brake pad,at binombahan ng hangin lahat ng disc brake harap likod, pero pag nag pa bleed ako ipapasama ko linis lahat ng preno,, salamat sir,,
    #6359
    1. check your brake booster tubing connections. baka may tulo.
    2. check the compressor that powers the booster.
    3. bleed your brakelines, po. baka may hangin na nag-expand kapag uminit at nag-retract pag lumamig.
    4. check brake pedal free play. baka halos wala, kaya laging naka-partial depress kahit hindi ina-apakan.
    5. check slave cylinders and adjacent lines. baka may partial-one way bara.
    6. check brake shoes. baka loose na ang lining at na-i-ipit..
    7. check master cylinder. baka kailangan nang palitan ang mga goma sa loob.
    whew! that's the entire brake system...
    hehe, mahaba haba ang listahan,, ,, ipapakita ko to sa mekaniko para my guide cla,, kung minsan kasi paisa isa lang kung mag check,,tapos sasabihin obserbahan,pag hinde ok babalik ka nanaman,,malaking tulong tong list atleast wala silang lusot pag nag pa-check,, salamat ng marami sir,,
    #6360
    ok,, papa check ko rin,, thank you sir,,
2008 Hyundai Starex (Gen. 4)
