Results 11 to 20 of 24
    Nov 2013
    Pwedeng malutong na valve seals o may basag na piston ring kaya may langis na sparkplugs. Kung valve seals lang top overhaul lang pero kung pati piston rings may tama eh general na yan. Have a compression test to be sure about your piston rings condition; pag mababa na compression mo yari na piston rings. Top would be around 6kish, general around 10kish, labor pa lang yan.
    Quote Originally Posted by funkeemunkee View Post
    6thousand or 10thousand?
    Apr 2016
    hi guys new here! same issue po sa honda VTI ko 97. pag galing ka sa biyahe then pinatay mo makina hirap mag start then tumatalsik na rin ung tubig pag nka open ung rad pag mag start ka. Just want to know if ano ano po most important palitan and gawin sa engine? and kay ba ito by DIY?
    Thanks po sa lhat ng mag re response.
    Quote Originally Posted by xRAMPAGEX View Post
    mahirap mag DIY ng engine overhaul kasi may machine shop.
    mga pinalitan ko
    valve seal, cylinder head gasket, oil seal, oilpan gasket, napakadami pang iba - wag ka pala kukuha ng replacement na valve seal kunin mo ung OEM, ung NOC - although same manufacturer ng OEM may sabalay pa din - di ko alam bakit ganun.
    Mar 2016
    bawat modelo may nabibili na nyang overhaul kit. Always use original kit para segurado. Overheating usually sa cooling system lang yan. Nagsisimula sa Radiator, radiator fan, pump motor, Thermostat, radiator cap. Sa bad cylinder head naman bukod sa overheating usually maputing usok, may langis sa tubig ng radiator, may bubbles na lumalabas kapag tinanggal yong radiator cap habang umaandar, kulay gatas na ang langis, matagal magstart kasi nga may tubig na ang dulo ng sparkplug. Yan yong mga kalimitang simtomas.
    Quote Originally Posted by oliverviray View Post
    General Overhaul na ba pag may nakita langis sa spark plug at sabi ng mechanic low compression daw, magkano pa overhaul top or general?
    costs of the parts stated are quite average.
    magkakatalo lang yan sa labor costs and quality ng gawa (based on reputation).
    Mar 2016
    Sir, sa akin umabot ng 8k top overhaul lahat lahat na ....kasi kulay milo na laging overheat din.. naghalo na tubig at langis..
    Mar 2016
    Quote Originally Posted by mjamolin24 View Post
    Mga sir.. may tanong din po ako.. kotse ko kc meron toktok kapag tumatakbo lalo na kapag lubak sya.. tapos kapag apak sa preno toktok din... ang sabi ng mekaniko sa rack end daw.. kc dapat ipapa-align ko kaso hindi nila inalign dahil may katok daw sa rack end nya palitan ko muna daw... pero napalitan ko na lahat pang-ilalim ng kotse ko... yong rack end lang hindi napalitan.. pero yong tie rod bago na din.. thanks.
    so have the rack end replaced and have it aligned.
    Mar 2016
    Quote Originally Posted by 1D4LV View Post
    Thanks po sa response
Top Overhaul Price Inquiries Civic vti 97
