Page 3 of 7 FirstFirst 1234567 LastLast
Results 21 to 30 of 81
    Sep 2017
    -I have 2007 City AT, pero nung 2013 started having problems with transmission, at first I experienced the blinking "D" indicator then the car suddenly felt slowing down as if running out of breath/being choked until mag complete stop na sya. Sliding problem daw yun.
    -CVT fuel was replaced pero everytime magchange ako ng gear from N to D may delay, especially REVERSE. hirap na hirap sya mag reverse.
    -Sabi ni HONDA need daw palitan buong transmission and siningil ako around 100k wala ako choice kaya pinapalitan ko na.
    -After the repair/replacement im no longer experiencing the transmission problem.
    -3yrs passed, the problem recurred, ganun na naman sya. same problem although this time pati condenser nagloloko na rin. maingay sya pag nagstart ng engine, change ng gear and worst pag yung reversing, nagjojolt. pinalitan na fan belt, magnetic clutch and nirepair na rin yung condenser. pero now nirerequire na palitan ng bago yung condenser.
    -gusto ko na sya ibenta dahil masakit na sa ulo, pero ayaw ko naman ,magpabarat kasi may problem sya. ayaw ko rin naman magpalit ng brand new transmission at wala nako budget.
    -may nagadvise sakin na flywheel lang daw ang kailangan palitan and not the whole transmission.
    -140k na yung mileage nya btw, and ipinagdadasal ko na lang na sana wag muna sya tuluyang masira habang naghahanap ako ng solution..
    -please i need your expert advice... thanks in advance.
    Quote Originally Posted by TengFu View Post
    get rid of it, sir.
    Feb 2009
    I had a jerking problem with my 2008 city idsi cvt everytime I try to accelerate and all we did was replace the defective ignition coils. Solved the problem in my case.
    Dec 2017
    Quote Originally Posted by hyperjigs View Post
    Sir pano po malaman pag palyado na mga ignition ccoil po? Ty
    Dec 2017
    Ganito rin problem ng 2008 i-Dsi ko...yung una yung
    Cvt nya...nagpalit na ko flywheel..nag ok na siya...
    Ngayon naman kapag galing ako ng brake at nag accelerate na at kapag slow moving traffic..yung tipong nakaalalay lang sa brake yung paa mu....nanginginig naman ang engine...nagpalit na ko ng engine support...malinis naman spark plug..change oil na din..pero meron pa din.
    Quote Originally Posted by Rick21 View Post
    ignition coils are known problems for these hondas...
    Feb 2009
    Agree! Own the same 2008 idsi and changed the ignition coils after 9yrs (orig surplus) but good as new and fuel efficient as ever! ;)
    Feb 2009
    In my case when you try to accelerate from slow moving to fast by pressing hard on gas there’s a jerking motion...
    Dec 2017
    Napa check ko na yung mga ignition coils and spark plugs..wala naman problema..ngayon papa check ko ang fuel filter..sana naman maayus na yung pag jerk ng engine...
    Jan 2018
    Ako din Honda city 2008 idsi AT. started sa jerking ng engine in reverse and eventually even forward motion. nag replace na ko ng flywheel and flushing ng transmission oil. media nabawasan ang katal ng makina.
    After 2 weeks from casa flushing, nag blink ang "D" and humina ang hatak. pinatay ko engine and tumakbo ulit ng maayos kaso nag fluctuate naman ang RPM.
    I will try to replace the ignition coils with original surplus and probably the fuel filter. Sana mayos na din to
honda city engine jerking
