Results 31 to 40 of 81
December 24th, 2017 12:47 AM #31
- Dec 2017
- 16
January 16th, 2018 10:22 AM #32Napa check ko na yung mga ignition coils and spark plugs..wala naman problema..ngayon papa check ko ang fuel filter..sana naman maayus na yung pag jerk ng engine...
- Jan 2018
- 18
January 29th, 2018 07:31 PM #33Ako din Honda city 2008 idsi AT. started sa jerking ng engine in reverse and eventually even forward motion. nag replace na ko ng flywheel and flushing ng transmission oil. media nabawasan ang katal ng makina.
After 2 weeks from casa flushing, nag blink ang "D" and humina ang hatak. pinatay ko engine and tumakbo ulit ng maayos kaso nag fluctuate naman ang RPM.
I will try to replace the ignition coils with original surplus and probably the fuel filter. Sana mayos na din to
January 29th, 2018 07:52 PM #34
Have you guys tried to change the CVT fluid? That generation was known to have problems on the CVT tranny
- Jan 2018
- 18
January 30th, 2018 08:39 PM #35
January 30th, 2018 08:55 PM #36
If im not mistaken the problem is the tranny itself. That is why Honda revertrd back to a normal torque converter automatic transmission on the next generation.
Hopefully its fuel filter related like what you said. Goodluck sir
January 30th, 2018 09:50 PM #37
if youre following the honda issues.. ignition coils are somewhat popular for older models...
- Jan 2018
- 18
January 31st, 2018 04:47 PM #38
February 1st, 2018 02:20 PM #39
Ask ko lang How did you check the ignition coils if it is properly working no abnormal or intermittent flow of current? I suggest try to replace them ng Original Surplus para sure po... Saglit lang yan palitan then test drive it before you pay the coils payag naman yun mga nagbebenta nyan sa banawe eh...
February 1st, 2018 07:38 PM #40
Ganyan din jazz ko. Pinalitan ng engine support, throttle body cleaning, change oil, spark plugs.
Tesla Philippines
