Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 55
    Aug 2012
    #31
    Quote Originally Posted by chay View Post
    Hi Sir Doddie, very informative post. we have the same car model. Ask naman ako contacts ng shops outside casa para makamura. Malapit lang ako nakatira sa Honda Otis.
    Issue ko is ung sudden 5 secs freeze from N to D. Plus ung hinde nagststart either sa P or sa N.
    thanks sir!
    thanks sir!
    sir mine is idsi 2006 at, ganyan din problem ko dati ,, jerking , nanginginig ,slipping, ayaw mag start sa P o N... dito din ako sa mga bossing natin sa tsikot nanghingi ng advice at tulong ,, pero i end up na ibenta nlang ung car ko ,, sarap na ng tulog ko kc if you back read talaga sa problem ng idsi eh sasakit na ang ulo mo.. kya i decided na benta nlang khit palugi ,, peace of mind pa din ang mahalaga eh ,, btw dun sa ayaw mag start sa p or n try mo mag switch off sa p tas konting rebolusyon bago patayin makina ,, good luck sir.
    #32
    Quote Originally Posted by page7fordoddie View Post
    thank you Boss for sharing, Baliktad naman sa'kin I initially checked the ignition plugs and spark plugs kaya na eliminate ko na yung jerking by misfire.
    Mel? as in yung sikat na Mel Casaba dito sa forum na tiga Bacoor?
    Share mo naman sakin magkano inabot change CVT mo at gaano katagal? Saka change CVT na agad? hindi mo na tnry change flywheel muna? yun kasi ang pinag iisipan ko ngayon eh.
    Please answer my questions ASAP. pasensya na a abala.
    email me doddie.gutierrez*gmail.com or SMS 0927 7555481
    Any updates in solving your problem with your car, sir?
    Sent from my Starmobile UP+ using Tapatalk
    Aug 2014
    #33
    Talked to Mel Casaba last friday and told me na try ko daw palitan muna mga ignition coil (all 8) kasi daw me napatino sya na ignition lang pinalitan. Ignition coil from casa is 4,800 each x 8=38,400k haha cannot be =)
    So nagpunta ako ng Banawe to get surplus. got all 8 for 12k (1,500 isa, surplus) pero i made a deal with the surplus owner na pag hindi tumino means hindi ignition coil ang problem so balik pera ko. PAuwi pa lang ako ramdam ko na walang nangyari me sakit padin so bumalik nako agad to get my money.
    Later (Thursday) will go to Mel's place at Cavite to leave the car there for observations and diagnostics. Update ko tong thread by saturday kung ano findings or kung change tranny na talaga.
    May 2011
    #34
    Goood day Sir,
    Pa-update naman.. thanks.
    Dec 2009
    #35
    Things i did since January:
    • Replace CVTF at Honda Otis, calibrated - observe.
    • Replace top valve cover gasket at Honda Otis - observe.
    • Change Oil (Motul fully-synthetic)
    • Change all Eight spark plugs, Air filter, Front disk brakes.
    Problems:
    • Vibrates paminsan especially pag heavy gapang traffic.
    • Normal gamitin if city driving if ang takbo is 60kph to 80kph driver only or with one passenger. pero if loaded like apat na passengers medyo nadedelay yung pag shift.
    • If expressway: till 80kph lang if dahan-dahan ang pagbuilt ng speed/momentum pero pag binigla mo ayaw nya, parang manual na humihingi ng shift pero ayaw mag gear-up. pero if unti-unti ang takbo eh nakaka takbo naman ng 100-120 kph.
    Sa observations ko, para sya talagang nagdedelay sa pag dagdag ng kambyo. parang Manual tranny na 80kph na takbo mo pero naka segunda ka pa din.
    Ano problema nito? sadly sa mga napagtatanungan ko eh out of stock ang flywheel. gusto ko na nga sana palitan as sugal move baka machambahan. - Since ang change tranny option is 15k surplus plus labor medyo mahal kaya gusto ko muna maka siguro na CVT tranny or Flywheel nga ang sira bago ko ipatira para hindi masayang pera.
    Please advice. email me doddie.gutierrez*gmail.com or SMS 0927 7555481 if seller kayo ng iDSI Flywheel at tranny for Honda City iDSI 2005.
    Thank You!
    Do you have the habit of keeping the gear in D and just use the break to stop then release the break to move again even in inclined (uphill) or levelled road?
    If the answer is yes, change your driving habit by shifting to N from time to time
    Jul 2012
    #36
    sir hindi kaya may palyado sa surplus na ignition coil? ako kasi bnew yung pinalit ko na coils.. replacement lang.. hindi from honda. ang kinabit ko yung IKI na brand.. parang napaisip kasi ako sa surplus. ihanda mo na sarili mo bro sa tranny replacement.. i suggest look for a trust worthy mechanic in replacing your tranny if needed. goodluck bro!
    #37
    Quote Originally Posted by nashimoto View Post
    How much for the (IKI brand, replacement) ignition coil you bought? How is the performance so far, from the time you purchased it?
    Sent from my UP+ using Tapatalk
    Oct 2015
    #38
    can you pm me your details?please thanks
    Jul 2012
    #39
    2k each.. so far ok naman wala ako issues sa jerking at idle.
    Dec 2007
    #40
    for civic es 1.6 ilan liters po need for change ATF?
Honda Automatic transmission problems P to D and R shutters
