Results 1 to 10 of 24
December 26th, 2009 04:04 PM #1
Guy's,
Any idea how much the following cost?
I'm using Civic 97. Yung price po below galing
sa mechanic ko orig naman daw po yung ipapalit.
Cylinder head gasket - P2,300
Timing belt - P1,600
Tensioner bearing - P800
Power steering belt - P500
Alternator belt - P500
Power steering fluid - P120
Oil seal - P250
Radiator fan - P800(surplus)
Thermostat - P300
Note: For comparison lang po, para malaman ko if
nasa range naman po yung bigay sakin. Thanks
Dref
- Sep 2006
- 43
December 27th, 2009 06:30 AM #3
Iyong labor magkano charge niya sa iyo . Huling nagpa top overhaul ako 2,500 ang singil sa akin. Kung ako sa iyo ikaw na mismo mag canvas ng presyo niyan para malaman mo price difference iyong matitipid mo pambayad na sa labor .
December 27th, 2009 09:14 AM #4
rbravo: may tagas ng langis dun sa may cylinder head gasket area kaya pinalitan, dahil nabuksan na rin eh pinapalitan ko narin yung ibang belts and seals.
speed: yung labor 3,000 singil sakin.
December 29th, 2009 01:33 AM #5
Paps,
Additional reference po,
Radiator fan motor - P1,600(orig)
Thermoswitch - P400
Note: Yung thermostat pwede tanggalin since mainit naman country natin.
Minsan sya nag cause ng topak ng radiator.
? Anyone po knows how much yung Vtech gasket!
- Oct 2014
- 2
October 26th, 2014 11:08 PM #6Sir ask ko lang po. hindi ko po kasi alam kung paano mag start ng new thread dito.
yun oto ko po sir Honda Civic VTI ph16 engine.
bale ang problem nya po sir one time nasa traffic ako, namatay yung oto ko then hirap mag start. then dinala ko po sa mekanik. ang ginawa tinangal yung radiator cap then ni start. natalsik po yung tubig, then ni check yung spark plugs sabe may tubig daw po yung sa dulo sa pinaka baba. and ang suggestion saken is mag pa top overhaul. tyaka pag long drive mga sir nataas yung temperature then diba pag long drive pag ni off mo yung engine then pag ni start hirap na mag start at may parang tunog na naputok putok. nag overheat na din kasi yung kotche ko dati. tama ba sir yung top overhaul? and how much does it cost kaya sir?
ps: newbee here sir
October 27th, 2014 12:52 AM #7
Look at the oil dip stick... Kung kulay milo na. Yun na yun.
Since bulwak na yung rad, almost sure na top overhaul na. Kaya sumisirit kasi may singaw.
Yes shave the head then valve lapping... Palit valve seals, head gasket, head cover gasket.
Cost Depende sa machine shop na papagawaan and mechanic na gagawa.
- Oct 2014
- 2
October 27th, 2014 03:00 PM #8Sir eto po yung itchura ng dip stick.
bale sir ang gagawin cguro dito yung sabi nyo shave the head then valve lapping sa machine shop yun diba sir?
then sir estimate lang po nyo magkano kaya yung valve seals, head gasket, head cover gasket for my engine.
salamat sa pag sagot sir.
- Dec 2008
- 4
January 6th, 2015 01:37 PM #9Mga sir hindi ko makagawa ng thread, ask ko lang po na top overhauled na ba masasabi pagmay nahalo gas sa langis o may iba reason pa.?
- Jan 2015
- 13
January 26th, 2015 04:05 PM #10General Overhaul na ba pag may nakita langis sa spark plug at sabi ng mechanic low compression daw, magkano pa overhaul top or general?
Tesla Philippines
