Results 1 to 10 of 15
- Sep 2009
- 21
September 3rd, 2009 02:18 AM #1Hi Sirs,
Ask ko lng po mga possible reasons kung bakit umiilaw un check engine ng recently acquired 99 VTI matic namin after ilan minutes na tumatakbo/idle.
Bago lng po ako dito sa tsikot and hindi din po ako ganon kadunong sa mga kotse.
Hope to hear from you and thanks in advance mga sirs.
- May 2007
- 104
September 3rd, 2009 06:43 AM #2safest way to to have it scanned. obd I or II ata yun. punta ka talyer na may scanner. wag ka punta casa tagain ka lang dun or singilin ka ng napaka mahal. there are many possible reasons why ur check engine is on when running. that means one of the sensors within the engine senses problem. it could mean speedometer / speed sensor is faulty just like waht happened to my civic. but there are plenty of other reasons why check engine is on.
September 3rd, 2009 06:58 AM #3
- Sep 2009
- 44
September 3rd, 2009 05:34 PM #4bro nangyari yan sa akin sa esi ko, pero di kasi gumagana dati ung odometer pero nung pinaayos ko yung odometer nag ok na ung check engine na ilaw.
- Sep 2009
- 21
September 3rd, 2009 10:02 PM #5Thank you po sa mga inputs nyo. Sir Mikhailer, may idea po ba kayo mgkano un scan na sinasabi mo? And ano pala un obd I or II? Sensya na po hindi ako dunong masyado sa mga kotse lalo na pag matic.
Thanks
- May 2007
- 104
September 4th, 2009 07:14 AM #6punta ka rapide or any talyer na medyo established for sure meron silang obd scanner. d lang ako sure kng magkano pero most probably less than 400 cgro un. scan lang naman eh, from there may lalabas na error code which pertain to a certain part na affected kaya umiilaw check engine.
- Sep 2009
- 21
September 4th, 2009 04:56 PM #7Thank you sir. Medyo inconsistent din kasi un CEL sa pag ilaw nya. Ipatune up na lng muna namin kasi hirap din pagnasa 2nd gear papunta sa 3rd gear e, pacheck na din ng mga timing belts etc. Tpos pag may umilaw pa (wag naman sana) dun ko na ipa odb scan.
Many Thanks po Sir.
September 4th, 2009 06:05 PM #8
- Sep 2009
- 9
September 7th, 2009 11:08 AM #9Here's a simple trick u can do... try taking out the negative sa battery for like a minute then return it back again... see if that works...
That's what we usually do in our cars...
September 7th, 2009 11:58 AM #10
pa check mo sa me scanner na talyer. kung QC ka try mo sa GTS sa may congressional road. pwede din sa casa ng honda pero medyo taga.
Tesla Philippines
