Results 1 to 8 of 8
- Dec 2006
- 234
October 19th, 2010 03:25 PM #197 Honda Accord VTI-S A/T, 2.2L
I recently have been hearing a grinding noise coming from the engine during cold starts, it goes away after the engine warms up ... could it be the oil pump? should i be worried?
I'm using Shell Helix 10W-40 oil, last changed two months ago.
- Apr 2009
- 1,902
October 19th, 2010 03:35 PM #2I have a similar case, which could be a wet compressor or pulley needing lubrication.
But it's more like a rusting torque sound from something that turns, and not like a grinding one.
- Dec 2006
- 234
October 19th, 2010 03:46 PM #3
- Apr 2009
- 1,902
October 19th, 2010 04:25 PM #4Some high pitch rotational sound heard when I turn the AC on a minute after a cold start
It eventually goes away as the engine reaches normal operating temperature.
But I wouldn't describe it as grinding.
I'm not sure about your case, because a similar noise is associated with timing chains, which I think is not used on your Accord (afaik, it uses timing belt).Last edited by isa1023; October 19th, 2010 at 04:40 PM.
- Dec 2008
- 421
- Dec 2006
- 234
November 8th, 2010 01:37 PM #6update to this, re observing again, it often happens after work when ive parked the car for 8 hours or more in the basement at RCBC and taking it up the spiral driveway while turning, I don't hear it when driving in a straight line even at speed ... CV joints? or?
November 10th, 2010 08:49 PM #7
ganito din problem ng ek namin dati, may grinding sound kapag cold start and eventually nawawala naman, nung pinacheck ko ang findings ng mekaniko is broken engine support so i have it changed and nawala na yung grinding sound, check mo sir engine support mo, baka same problem din nung sa akin...
November 10th, 2010 08:50 PM #8
Tesla Philippines
