Results 2,331 to 2,340 of 3405
- Aug 2008
- 498
October 16th, 2018 10:32 PM #1
October 16th, 2018 11:25 PM #2
Bro jigeloh: I Had the same watery problem before on my civic fd2. It turned out the that butyl tape aka "katol sealant" of the plastic covering of the inner door had already lost its adhesiveness thus allowing water to seep in the car's cabin.
If this is the case, the best remedy is to buy a "katol sealant" from your suking car supply shop. the 1st thing to do is to carefully remove your car's door panel. the next step is to clean & remove the old butyl putty from the plastic sheath & then re-apply the new butyl paste to it again. once done, plaster the elastic sheet back to the door shell in order to make your car's interior water proof anew.
Medyo matrabaho siya if you diy it pero am sure hindi na water compromised ang integrity ng car doors mo.
Here are some pics of my diy fix-it:
Before:
after:
the katol sealant aka butyl tape:
Sent from my ASUS_Z00AD using TapatalkLast edited by baludoy; October 17th, 2018 at 12:33 AM.
- Aug 2008
- 498
October 17th, 2018 07:04 AM #3
October 17th, 2018 09:24 AM #4
October 18th, 2018 09:05 AM #5
After 3 years, napundi na yung headlight bulb ko. Any suggestion ano magandang replacement bulb?
- Sep 2016
- 19
January 7th, 2019 01:55 PM #6sakin din sir napundi na. bumili na lang ako generic brand basta same ng specs. nag-ask kasi ako sa Casa, nasa 2k din compared sa generic na nasa 100 pesos lang. But still up to you. So far, okay naman yugn generic sakin. I've been using it for almost 3 months now.
Noted sir! Thanks sa quick response!
November 26th, 2018 02:13 PM #7
Most of the 09-13 GM’s also had no Hood insulator. Ka-partner yan ni trunk insulator. So if the hood insulator was deleted most probably the counterpart also suffered the same fate.
I bought and installed these two from Honda Marikina years ago. Para kasing may kulang everytime i open them.
- Oct 2008
- 213
January 4th, 2019 09:31 AM #8Anong tawag sa ilaw located somewhere near on top of the USB port and lighter port? anyone knows how to access it? thanks
- Sep 2016
- 19
January 7th, 2019 01:50 PM #9Hi mga boss, i'm planning to do my 50T KM Check-up this weekend. Here's the rough estimate na binigay sakin:
Materials:
Fully Synthetic Oil - 2628.00
Flushing - 460.00
Petrol System - 800.00
X1R Engine Treatment - 1000.00
Materials - 308.00
Car Care Kit - 280.00
Honda Brake Fluid - 50.00
Top up Coolant -140.00
I know, optional yung X1R. Ask ko lang po what else po yung pwede ipa-remove diyan sa list? I think flushing and coolant? Please confirm po. Thank you in advance!
January 7th, 2019 01:52 PM #10
Tesla Philippines
