Results 3,271 to 3,280 of 3405
October 16th, 2018 11:25 PM #3271
Bro jigeloh: I Had the same watery problem before on my civic fd2. It turned out the that butyl tape aka "katol sealant" of the plastic covering of the inner door had already lost its adhesiveness thus allowing water to seep in the car's cabin.
If this is the case, the best remedy is to buy a "katol sealant" from your suking car supply shop. the 1st thing to do is to carefully remove your car's door panel. the next step is to clean & remove the old butyl putty from the plastic sheath & then re-apply the new butyl paste to it again. once done, plaster the elastic sheet back to the door shell in order to make your car's interior water proof anew.
Medyo matrabaho siya if you diy it pero am sure hindi na water compromised ang integrity ng car doors mo.
Here are some pics of my diy fix-it:
Before:
after:
the katol sealant aka butyl tape:
Sent from my ASUS_Z00AD using TapatalkLast edited by baludoy; October 17th, 2018 at 12:33 AM.
- Aug 2008
- 498
October 17th, 2018 07:04 AM #3272
October 17th, 2018 09:24 AM #3273
October 18th, 2018 09:05 AM #3274
After 3 years, napundi na yung headlight bulb ko. Any suggestion ano magandang replacement bulb?
- Feb 2007
- 41
October 30th, 2018 05:45 PM #3275
- Nov 2018
- 3
November 15th, 2018 10:09 PM #3276Hi guys, need some help:
I recently bought a 2018 Jazz V CVT and yung under hood nya has no insulator. I checked a 2014 V CVT and meron syang insulator na naka install.
I asked my SA and according to him wala daw talaga but I’m still skeptical. The hood kasi is very hot kahit saglit lang ako nag drive. I checked the net and most ng nakita ko may insulator but not sure if it is a 2018 model.
To all 2018 Jazz V owner out there pa confirm naman if meron or walang hood/bonnet insulator yung unit nyo? Thanks a lot!
November 15th, 2018 10:27 PM #3277
November 16th, 2018 06:35 AM #3278
- Nov 2018
- 3
November 16th, 2018 06:43 AM #3279
- Nov 2018
- 3
November 16th, 2018 06:45 AM #3280
