Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
    Nov 2007
    Quote Originally Posted by jisantos View Post
    Pa OT po.
    Mga boss LXI 1996 ph15a engine carborator parin pa po ba to or nd na po. mejo naguluhan lang po kasi ako.
    salamat po sa mga sasagot.
    Fuel injected na ang model na ito.
    Nov 2011
    Quote Originally Posted by ans_lim168 View Post
    Thanks a lot sir.
    Nov 2011
    Again and again i need the masters to help me.
    My car last day was overheated extremeheat kasi sinira nya cylinder head ko at marami pang part ang nasira. Now i buy all that part need to be replace even the cylinder assembly.
    Now my car is running again but the day i got my car sa motorshop na pinagpaayusan ko after and half hour na test drive, the engine check lit up. So i run again to the shop kasi ala pa 1hour ganun na sya. They check sensors even the sensor of my regator fan, nakasaksak sya sa sensor but it is baypas na so they remove. Test run ulit again the check engine lit up, now they remove my intake manifold yung parang carburator they clean up sabi baka madumi daw, also all the socket of sensors they spray w40 to remove the rust daw. Pagkatapos nito we test drive again my car. Now mawala na ang check engine.
    The problem is cleaning lang naman ang ginawa nila so may pag asa po pa na bumalik kaya ang engine check?
    Sa takbo pala ng sasakyan ala naman nabago, the same parin.
    Also my problem now is where to find speed sensor for my car. Nasira kasi putol ang gitna na paa nung socket nya.
    If any one have available speed sensor on hand i willing to buy just PM me.
    Speed sensor for Honda LXI PH15A engine, 1996 model and part number- 41205r15
    Sep 2009
    Mga Sir, pareho lang ba ng makina ang 1996 at 2002 model?
    Mga Master may problem kasi ako sa kotse ko at dalawang Motor Shop na ang sumilip at wala daw silang makita. Problem is yung tumutunog sa rear left side ng kotse pag nalubak yung lubak na mababaw lang naman pero pag ala medyo malalim na lubog sa kalsada ala tunog.
    Done:
    Last April,2012 when to Honda Service nagpapalit na ako ng rubber bushing apat na sa harap at likod.
    Kaya lang natunog parin.
    Check na nila lahat nung dalawang motor shop. Sinikwat na lahat ang shock maganda daw yung shock, sinilip na lateral nung kinakabitan ng bushing maganda naman daw tas yung isa ayos na naman daw din. sa left side pala rtear sa gulong tas ngayun tinuturo ulit ng mga shop mahina daw yung kinabit na bushing ng honda at yun ang pinapalitan ko.
    Help naman po.
    same here 96 VTI sa rh side siya meron tunog hindi makitya kung saan galing.
    Nov 2011
    Sir i have problem with my car. LXI PH15A engine.
    Mga sir ang problem nya i pagtinapakan ko CLUTCH nya tumataas RPM nya, pagtumatakbo lang naman po pero pagtigil sya maganda naman po idling nya. Pagrunning na po ako tas tinapakan ko CLUTCH umaabot ng 2rpm nya tas pagbitaw ko ng CLUTCH bumababa po ulit. Anu po kaya ang problem nun?
    Sep 2016
    Mga Boss magkano kaya aabutin pagawa front at rear bumper ko may punit siya konti at repaint nadin?
    boss, had the same problem before(96 vti). after changing all bushings (front & rear) including stab links, ball joints & tie-rod ends, may tumutunog pa rin. finally had the steering box adjusted, ayun nawala! parang bago na naman!
    Oct 2009
    Quote Originally Posted by louieochoa18 View Post
    sa evangelista ako naka bili ng brandnew replacement plastic only walang paint.3.2k ang kuha ko harap likod.ikaw na mag pa paint,...
    about nman sa lagutok.na solve ko din ung sa akin.ang problema ay ung pinaka washer niya sa shock maluwag na siya.ung washer na nilalagay sa shock tapos ung shock cover (tabo) saka ung shock mount niya .at wag masyadong higpitan ung nut sa ibabaw pag ikot ng pinaka ehe ng shock sa pag higpit ok na..
1996 Honda Civic LXI 1.5 cc
