Page 11 of 24 FirstFirst ... 78910111213141521 ... LastLast
Results 101 to 110 of 233
    Apr 2008
    #101
    Quote Originally Posted by albert_b View Post
    sige sir, I'll try to take a picture tonight.
    Btw, would you know sir if the Mobile XT application itself can be upgraded?
    i really dont know but my uncle has garmine mobile xt in his iphone 4 may mga updates siya.
    it will be nice kung ma pipicture mo yung accuracy thanks
    by the way try moving the car while getting the accuracy. minsan kasi 10m then pag linipat mo ng puwesto maraming satellite ang mag lolock in kaya tataas ang accuracy mo from 10m will go to 4 . pero sa iphone kasi ng uncle hangang 10m lang talaga
    Apr 2010
    #102
    tried pressing the signal meter located at the upper left part of the screen while on GPS mode.. it showed elevation and speed of travel, on the left side it showed the same circle drawing with blips with numbers.. im assuming those are satellites..
    on the right side are some slightly moving bars, around 7 to 10 of them... but i didnt see any number of meters for accuracy.. sorry im at work today, cant show the picture I took from my camphone.. maybe tommorow when I get home from work.
    Apr 2008
    #103
    Quote Originally Posted by olidotcom View Post
    thanks sir in advance. paki post po thanks
    Feb 2011
    #104
    Sir pwede ba yan sa City 2010?
    Sep 2004
    #105
    I got the same as si Oli. No accuracy pero from my use ok naman siya. I've never been placed in the wrong place (as long as may satellite signal ofcourse).
    I tried to use the other facility outside of the Mobile XT and this is how it looks naman
    Apr 2010
    #106
    ayoowwn! ganyan na ganyan din sakin! ahihihihihi!
    #107
    Quote Originally Posted by jedi View Post
    we are installing the head unit to another nissan livina owner
    thanks sir sa unit!! baliktad lang kabit sa camera pero dali lang naman ayusin yun. also, ok yung fix niyo para sa radio antena...
    #108
    i tried putting a different garmin xt sa unit ko. check ko maya kung me accuracy na makikita. as for the map itself, talaga bang parang split yung screen sa right side? hindi kasi buo eh, im trying to look for a fix. also sa GPS din, pag nag type ba kayo or search anong keyboard ang lumalabas? wince kasi yung akin eh, nung nagpalit ako ng garmin xt saka ko lang napalabas yung keyboard ng Garmin.
    btw, how do i change the boot logo?
    TIA
    Sep 2004
    #109
    :-) Those are what Oli and I are also trying to figure out.
    Apr 2010
    #110
    yep... same issue on the right part of the screen.. since garmin xt is for windows ce or cellphone use only.. medjo malaki laki yung monitor natin.. so malamang.. yun ang side effect. hehehe..
2din HD DVD TV GPS Rear Camera
