Page 34 of 43 FirstFirst ... 24303132333435363738 ... LastLast
Results 331 to 340 of 425
    Apr 2010
    #331
    Quote Originally Posted by 17Sphynx17 View Post
    When things do "die down", hopefully hindi yung RFID to go type, pwede na enroll sa Auto Debit with a Credit Card para convenience na din and di na nga mangyari yung "late topup" or "late reflection of topup" when you arrive sa toll booth.
    The forms are simple enough to accomplish. But there is no way to submit it online for either as far as I am aware kaya nung nagupdate ako nung sept/oct this year ng ADA, had to find an open kiosks na tatanggap lang (since wala naman sila need gawin sa kotse and just receive the papers). Malas lang kasi nagexpire yung card na and nagupdate na bago, so need to update talaga. hehe!
    paano ba ung ADA? monthly charging ba arrangement to credit card? I would like to know and probably do it through ADA if its more convenient.
    Jun 2005
    #332
    Quote Originally Posted by n0cary3t View Post
    Set ka ng limit sa account. Then kapag bumaba duon ang load, magcharge sya sa card ng preset amount.
    Sent from my MI MAX 2 using Tapatalk
    #333
    May form you can download online from Easytrip Website (Autosweep also has it available for their own ADA Arrangement).
    You set a "threshold minimum balance" that will trigger their system to request a "reload amount".
    Threshold I set to the minimum of 500php.
    Reload amount I set it to 1000php naman (minimum din).
    But in your case if frequent user, you might want to either increase the threshold amount or reload amount. The only reason I see with increasing both is if you have multiple vehicles for a "GRAND FAMILY ROAD TRIP" na sabay sabay kayo dadaan sa toll gate and nakalink lahat sa isang mother/main account.
    https://www.easytrip.ph/forms/Author...d%20Charge.pdf
    #334
    actually ok nako sa sistema ko now. bpi topup kasi less 1 hour credited na. since lagi naman may laman yun rfid ko, bago umalis naka topup na. bago pa makarating or lumabas sa exit sure na may laman. minsan bago pako umalis, sinisigurado ko na loaded na e.
    masaklap bro mabagal mag credit yung sa iba toptup or di talaga niload. so kahit handa ako maiipit parin ako along with them.
    Sent from my Redmi Note 9 Pro using Tapatalk
    Ic. Wala na ako BPI. hehe! But aware din ako sa Gcash or Paymaya method.
    Pero kahit ako na nakamonitor sa lahat, takot lang ako machempo na mag "Divert" ako to an expressway out of the blue na hindi part ng supposed route. hehe!
    But to each his own and aminado ako, ulianin din ako sa monitoring before. Mas after ako to check pag nakadaan na ako and yung nakita ko sa screen na nagbelow 500php na ako so hahanapin ko yung topup request sa ccard ko and sa SOA para sigurado once lang ako kinunan. haha!
    Aug 2004
    #335
    Reloaded via mobile app > bpi. Instant credit naman. Di lang pwede mamili ng amount. 500 minimum plus 25 service fee.
    Sent from my SM-A605G using Tapatalk
    Apr 2010
    #336
    thanks sa info.
    sa tingin ko okay lang 500 threshold then siguro dagdagan ko nalang reload amount to save sa charges.
    any idea magkano total charge sa ADA arrangment? baka kasi madami hidden charges.
    cannot access din FAQ ng easytrip to check the charges.
    #337
    thanks sa info.
    Sa Autosweep sure na no charge yung ADA.
    Sa Easytrip I can't remember the amount charged. Matagal na di nakareload but alam ko meron.
    #338
    Nagalit na Valenzuela mayor sa nlex. Nag banta na baka revoke ang business permit.
    CNN Philippines - Valenzuela City Mayor Rex Gatchalian... | Facebook
    #339
    Laki talaga problema netong NLEX.
    Temporarily unavailable mag load sa GCash.
    Hindi din available sa 7-11.
    Pag through BDO Online app, dati the following day credited na sa account, now at least 2 days bago ma-credit.
    Signature
    #340
    thanks sa headsup bro, will load na kahit may almost 400 pa ako. baka bukas pa magka aberya
NLEX EC Tag Concerns
