Results 21 to 30 of 41
November 27th, 2024 12:49 PM #21
- Jan 2007
- 2,452
November 27th, 2024 01:22 PM #22
November 27th, 2024 01:27 PM #23
Yes, totally agree. Should've been more precise.
The 30% is a big number but in the grand scheme of things, it's still a drop in the bucket. Acceleration and cruising gets the bulk of your fuel consumption.
However, if you add up just the idling times with the shifter on D, you can extrapolate how much fuel (by getting the 30% of it) was from parasitic load by the A/T.... then that figure becomes significant.
November 27th, 2024 01:51 PM #24
November 27th, 2024 06:57 PM #25
Battery almost depleted ... engine starts to charge ... but must be in Drive to be able to charge ... read this somewhere and also one reason why they don't recommend shifting to Neutral at stop light ... but will still shift to Neutral for safety reasons ... what happens if you get distracted and transmission in Drive? ...
November 29th, 2024 09:19 AM #27
Wala na ganyan. AT will last for the life of the car as long as you regularly maintain it.
Wala na din neutral sa stop dahil meron na brake hold pag masyado matagal naka stop nama automatic siya mag shift to P
- Nov 2019
- 1,239
November 29th, 2024 09:30 AM #28
November 29th, 2024 10:20 AM #29
- Nov 2019
- 1,239
November 29th, 2024 10:46 AM #30Yan din yung naisip ko.
Pero I remember the Honda CRV and Honda Civic is now using shift by wire ba tawag dyan?
Yung pindot2 nalang ng button para maka select ng Gear.
Mag make sense din if button na ang type ng gear selectors.
Pero it won't make sense sa mga naka traditional gear lever selectors na AT.
Tesla Philippines
