Results 11 to 17 of 17
May 22nd, 2003 01:59 PM #12
ako ganyan ang ginagawa ko. mas gusto ko yung shift to N from D para hindi na ako tatapak sa preno. kapag naka D kasi sa traffic eh moving forward pa din kahit di mo tapakan gas pedal.
- 82
May 22nd, 2003 02:16 PM #13Sa matic
Basta normal driving conditions, D ka na lang bahala na siya mag shift. If on an incline, kaya pa ng nas D yan wag lang madulas or may snow (wala naman tayo) lagay mo sa L. Sa stop and go pwede na nasa D lang unless extended yung stop lagay mo sa N.
Don't ever shift from D to R or vice versa while vehicle is still rolling, kailangan stop na siya.
Kung gusto mo mas matipid sa gas, pag andar, depress accelerator for a while tapos press uli para ma control mo shifting niya. Depende sa tapak mo, kung at what RPM sya automatically mag shift.
Ano pa ba, nasabi na nila lahat. OK ang matic you don't get tired driving, iba ung pagpamper sa yo
May 22nd, 2003 03:18 PM #14
You should shift to "N" if you are stopped sa traffic light to relieve driveline stress. Be sure that you are fully stopped when shifting in and out of "N".
May nasira na kaming tranny because of not shifting to "N" while stopped.
- Jan 2003
- 611
May 22nd, 2003 03:47 PM #16once i tried putting it sa P ng hindi pa fully stopped... ayun sumubsub aku :oops:
May 22nd, 2003 03:50 PM #17
subsub ka talaga nun... but in the long run, the pin in that gear would break and you wont have 'Park' as an option..... use parking brake then put it in P. heheheh..
