Page 2 of 8 FirstFirst 123456 ... LastLast
Results 11 to 20 of 79
    Yung Bosch horns ko din noon.. nabasa lang nung nagpaunderwash ako ayun nangongo na tunog
    un sa caravelle namin.. isang araw pa lang.. lintek na hella un.. sayang pera...
    Jan 1970
    I've been looking around and specs-wise, the Hella Supertones win.
    Hella Supertones: 118db * 6'
    Stebel Nautilus: 115db * 6'
    As for the Fiamms, ang nakikita ko lang is some models are rated *130db but walang nakalagay na distance.
    Sa Supertones, they have the additional advantage/disadvantage of being semi-directional.
    Sa durability, case to case basis talaga. Masyadong varied yung mga experiences ng iba sa Fiamms, Hella and Stebel.
    *GlennSter and odell
    Anong model ng Hella yung nasira agad sa experience niyo? My old/stock horns were Hella's kase and they where mounted sa front grill. Recently lang nasira kahit na laging exposed sa elements.
    Dec 2003
    i have bad experiences with HELLAS.madaling masira eh..taposs pag nabasa..iba na agad ang tunog pag pinatuyo...fiamms..minsan nabasa na...buo parin ang tunog.
    Hindi ko alam na pagnabasa pala ang Hella nagbabago ang tunog..Yan pa naman ang balak ko ilagay sa Optra namin...:D
    For me the best pa rin ang Bosch Supertones...:D
    comparing the snail type horns mas malakas pa rin Yung stebel magnum. Ang katumbas nung Bosch supertones and FIAMM snail type yung Stebel TM 80. Stebel Magnum mas malaki compared to the other snail type horns
    mas malakas ba ang snailtype na FIAMM kesa stock horns?
    Signature
    Feb 2004
    sirs, ano ba ang mga dapat bantayan kapag nagbago ng horn?
    for example, installing a stebel nautilus... additional relay lang ba ang kailangan?
    Yung Stebel Nautilus hindi kasya sa stock horn location ng Pajero.
    Mine is on the passenger side fender near the firewall (where it is safe from floods).
    Aftermarket horns draw more current from your stock horns. Additional relays will help produce its sound more efficiently. Airhorns such as Nautilus Stebel should be pointed down so as not to trap water in it.
  10. #20
    basta wag kayo kuha ng Bosch...2 beses na ako nagpalit, nabasa lang ng konti sira na.
Horns/busina query
