Results 11 to 20 of 45
- Oct 2015
- 922
February 10th, 2016 07:46 PM #12
Lorry is about 1-2M, depending on the size. That's fr a surplus truck. If you go brand new, 2-3M for a tractor head, another 1M for the trailer.
Then there's the maintenance cost. Plus driver. Never mind the salary, there's always the risk that your driver will engage in shady business and make "paihi" your delivery - you'll be losing hundreds, if not thousands of liters per delivery.
Back in the day, Petron will build you a bulilit station where your investment is just about 3M for the civil works, but they'll provide the pump and tank. Downside is that you'll have small margins, and you have no leverage vs the company because they own everything.
Now, most companies prefer that you cover all the capex. Although some smaller companies (Total, Seaoil) will still cover the capex for the pumps/tanks, or at least let you loan it from them.
But at the end of the day, your total capex will still be significant, and unless you generate good volume, you won't get your ROI within 5 years. Very few new stations get good volume, the market is just very saturated right now.
February 26th, 2016 07:22 PM #13
Daming on-going construction ginagawa sa stretch ng TPLEX, yung iba sobrang haba.
Pero sa tingin ko hindi lang pang gas station ito, but wondering how high is the put up capex?
February 26th, 2016 07:53 PM #14
Sir Jut, question lang po. may pinagkaiba ba ang binebenta na gasolina ng isang generic gas station vs branded gas station?
February 26th, 2016 08:15 PM #15
On SCTEX, PTT and Seaoil na magkatapat but opposite directions ang tinatayo. On TPLEX, dalawang Petron na magkatapat but opposite sides.
Yup, walang additives yung sa generic. But it's mostly the same base fuel.
- Jan 2013
- 1,851
February 26th, 2016 08:19 PM #16Di lang naman gas station yun. Like the gas stations along SLEX and NLEX may mga restaurants and convenience stores.
Last time na nag Baguio ako ang haba na ng TPLEX nakakainip kasi wala ka man lang matigilan or jingle break. Napansin ko rin yung mga construction na yun which is good for travellers.
February 28th, 2016 02:04 PM #17
I recall SeaOil had that 2m offer, as well.
Small stations are a financial dead end. Unless you have a completely captured market, you'll go bust in just a few years. So many small stations here in the province exchange hands every two or three years. Just not enough volume to stay solvent.
February 28th, 2016 02:11 PM #18
General rule of thumb, if you're building a branded station in the province, you should have a secure volume 80-100 thousand liters per month. Otherwise it won't be a very profitable venture.
If you're going independent/generic, you should get at least 40 KL per month. Much lower volume required to stay afloat because generics have much higher unit margins and lower fixed costs.
- Jun 2009
- 838
February 29th, 2016 03:57 PM #20
Tesla Philippines
