Page 9 of 11 FirstFirst ... 567891011 LastLast
Results 81 to 90 of 102
    Apr 2006
    #81
    thanks, i scanned the previous post but am not sure if dallas auto service in morato is still open. do you have any idea kung bukas pa dallas? i'm from the province kasi so i seldom go to qc unless may lalakarin. i would like to get the names of the stores where it is available so hindi masayang biyahe ko. thanks again and i hope someone else can help me find such stores.
    #82
    Buy and Sell magazine pre, laging meron nag post.
    Apr 2006
    #83
    Quote Originally Posted by theveed
    Thanks a lot pre. will check it out.
    #84
    this guy at Grupo Toyota (www.grupotoyota.com.ph) sells Cathodic Rustproofing.
    Aug 2003
    #85
    hi all!
    i saw this product sa Ace Hardware not so long ago; it's supposed to convert iron oxide into iron phosphate, on which you can paint on.
    ok ba to or panloloko lang?
    Jan 2004
    #86
    no sir, ok itong rust converter na ito. turco ang brand. mas maganda gamitin ito sa mga bakal na masyado nang makapal ang kalawan na kahit kaskasin e ayaw pa rin. yes pwede mo nga syan pinturahan.
    #87
    not advisable to use on heavily rusted metal. dun sa mga light rust lang. kaskasin mo muna yung light rust with sandpaper or wire brush, then apply the "rust converter". what it basically does is to form a protective iron phosphate film on top of the un-affected iron or metal part w/c supposedly will prevent further oxidation or corrosion of the metal. Kung heavily rusted na, one of two things can happen, either mag slow down lang further corrosion, or bibilis lalo yung pangangalawang since this turco rust converter is basically just diluted phosphoric acid with some wetting agents (maybe not sure :D ).
    #88
    ok yang rust converter. btw d yan permanent solution sa rust..
    Sep 2005
    #89
    saw that product also at ace hardware. 300 ata price. and yep, di is not a permanent solution but to slow the build-up of rust once applied.
    Jan 2004
    #90
    aba ang mahal pala. meron din yan sa mga suking hardware & construction supply. turco ang pangalan. nasa amber na glass bottle.
Electronic Rustproofing/Anti-Corrosion device [MERGED]
