Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
    Aug 2019
    Thank you sa replies. Maybe di ko naclear un pagsabi na pag mag 30 kph na speedometer mag shoot up un rev ko.. may kakulangan man, di naman siguro appropriate na isagot eh may lisensya ba ako..... anyways salamat sa pagsagot will bring it sa mekaniko today and hopefully, i will get lucky. Have a good day everyone.
    Aug 2019
    Sunget mo naman... kulang kulang kasi info mo kaya ganyan sagot..
    Kung AT yan.. clutch slipping ang tawag dyan.. malamang between 2nd gear to 3rd gear yung slip na nararamdaman mo based sa speed mo na 30 to 40 kph..
    Check your atf level, color and smell.. check level while engine is idling. cycle the shift stick to all gears. When the rad fan kicks.. check atf level between Hot zone.
    Using tissue paper (white) check its color.. should be reddish in color. Then sniff the atf for any burnt oil smell
    Hahaha sunget ba? I dont think I can be funny enough when i think na baka may mangyari sa akin at sa kotse while driving pag nagkaganoon nga un pag rev bigla ng sasakyan. I will try to be more clear next time to avoid any misunderstanding
    Jan 2008
    Quote Originally Posted by Nyaminya View Post
    Try mo muna flush atf then replace atf filter.. search mo lang car model mo kung may atf filter..
    MAKE SURE TO USE THE SPECIFIED AT FLUID!!
    wag maniniwala sa mekaniko na pwede yung universal atf
    yup.
    civic ini. even if 20 years old.
    get it from the honda casa.
    may history na ang honda vis a vis transmission fluids.
    'buti na yung sigurista. that way, we will be removing one possible, even if unlikely, variable, from the equation.
    Hopefully makuha sa atf change. Sa xtrail namin, hindi nakuha. For city driving naman lang ginagamit so since hanggang 60kph naman yung 3rd gear niya, medyo usable naman and walang real world issue
    Aug 2019
    Thank you for the replies. Now , any suggestions where is the better if not the best place to have an ATF flush.
    Kahit saan talyer or gasoline stations if you're just gonna do drain and fill.
    You could try Exalta. N. Roxas St., Banawe area. Ask them how much atf you'll need.
Civic suddenly revs
