Results 1 to 10 of 18
- Aug 2019
- 19
February 28th, 2020 08:37 PM #1Good day po.. i just want to ask, my honda civic 1997 just suddenly increases rpm when ever i step on the gas... i tried to observe when i happens, and i noticed that when ever i reach 30 ro 40 kph may rpm just suddenly shoots... para tuloy nirerevolution un kotse bigla.. i release the gas pedal and it stops.. ano kaya nangyari? Thanks in advance.
- Apr 2019
- 38
February 28th, 2020 11:24 PM #2
February 29th, 2020 12:04 AM #4
- May 2006
- 1,668
- Aug 2019
- 19
February 29th, 2020 07:43 AM #6Sa mga sumagot sa akin question, it seems ang gagaling na ninyo magdrive. Yes I have had a drivers license since 1997 i have been driving manual and automatic, in the philippines and in north america. My car is a honda civic 1997 AT Vti. I dont think it is driving style... normal ba na tataas un rpm kapag magaccelerate na di na aakyat ang speedometer pero un rpm tumataas pa din? Na parang nakastand still un sasakyan pero parang nakaneutral habang nagrerevolution un engine? I dont think normal yun and i have driven enough years naman na siguro to know if it is normal or not.
- May 2014
- 1,318
February 29th, 2020 08:18 AM #7Magkaiba kasi ang original post mo at ang reply mo ngayon.
Malaki ang pagkukulang sa original post mo kaya normal ang reply sa iyo.
Ngayon mo lang sinabi na umaakyat ang rpm pero hindi tumataas ang speed. Ika nga, wording malaki pagkukulang.
Sa sinabi mo, hindi ko sure kung anu issue diyan pero baka, baka transmission related na nawawala yung higher gears na at hindi makapag shift up.
Ang nearest experience ko lang is 2003 xtrail ng kuya ko, hanggang 60kph lang takbo at 2500 to 3k rpm na kami wala na talaga ibubuga yung kotse. Overdrive on or off, same situation, so naging suspect, nawawala na yung 4th gear sa shifting option ng kotse.
February 29th, 2020 08:38 AM #8
Based on those symptoms, my best guess is that that the clutch is slipping.
If it's still using the original clutch packs from 20+ years ago, it's definitely time to replace them. Otherwise, it may just need certain adjustments or an ATF change.
- 53,883
February 29th, 2020 08:49 AM #9MT? the clutch (disk) is probably worn and needs replacing.
AT? atf only, if you are lucky. AT needs to be opened, if you are not that lucky.
i recently had my altis's AT fixed. the stick wouldn't rake nicely. first time i heard of "AT overhaul kit". it costs a pretty bundle.Last edited by dr. d; February 29th, 2020 at 09:36 AM.
- Jan 2008
- 4,726
February 29th, 2020 09:28 AM #10Sunget mo naman... kulang kulang kasi info mo kaya ganyan sagot..
Kung AT yan.. clutch slipping ang tawag dyan.. malamang between 2nd gear to 3rd gear yung slip na nararamdaman mo based sa speed mo na 30 to 40 kph..
Check your atf level, color and smell.. check level while engine is idling. cycle the shift stick to all gears. When the rad fan kicks.. check atf level between Hot zone.
Using tissue paper (white) check its color.. should be reddish in color. Then sniff the atf for any burnt oil smell
Tesla Philippines
