Results 41 to 48 of 48
- Jul 2013
- 83
May 30th, 2020 02:43 PM #42
June 6th, 2020 04:55 PM #43
Just to update this thread, the unit was brought to Ford Commonwealth. There was an error on the crankshaft sensor kaya namamatay engine during or about to idle. The fault was fixed, ok na ulit. Damage was 3.5k.
- Feb 2003
- 1,038
June 9th, 2020 09:56 PM #44
- 53,883
June 9th, 2020 11:14 PM #46
Crankshaft sensor? Is that the same as a magnetic pick-up? the one located on the bell housing for counting the revolutions of the flywheel by generating an electrical pulse for each pass of a flywheel tooth? Those things last forever. Or should i say "used to last forever"???
If it is not damaged adjustment lang yun dapat. Distance from sensor to flywheel tooth is 3/4 turn out - tighten until the sensor touches the tooth of the flywheel, loosen 3/4 turn, tighten the lock nut. Or if you want to be by the book, use a 0.6 mm feeler gauge
- Feb 2003
- 1,038
June 9th, 2020 11:22 PM #47Kung ganun ang mahal naman adjustment luwag or tightened moves ng Casa nun hehe.
Most of the problem is also poor contact ng mga electrical connectors from the main harness, happened na sa ken. Disconnect Spray contact cleaner and snap it back in. Reset via OBD clear codes.
- Nov 2009
- 3,503
June 10th, 2020 07:08 AM #48Stretched timing chain and worn chain tensioner guide could often lead to misdiagnosing electrical and cam/crankshaft sensors. Check the chains if problem recurs.
Tesla Philippines
