Page 706 of 778 FirstFirst ... 606656696702703704705706707708709710716756 ... LastLast
Results 7,051 to 7,060 of 7777
    #7051
    Back view yan? Looks like may screw lang yung horse so pwedeng alisin. Pero malapad yung frame sa sides.
    Need ko ng honeycomb grill kasi yung offroad lights na ilalagay ko will be behind the grill, "stealth install". Need offroad lights kasi as back up when i go to my farm and i go home late. Ayaw ko naman maglagay ng nudge bar for the lights.
    Aug 2017
    #7052
    Hi,
    Anyone using 275 55 R20? Still using 265 50 R20, I wonder kung magkaka issue if i change it to 275 55 R20 for 3.2 Titanium +.
    Thanks
    Quote Originally Posted by cend View Post
    Hi,
    Thanks
    no rubbing issue. unles you exceed payload capacity
    Aug 2017
    #7054
    Thank you Sir.
    Any suggested brand? currently looking at nitto grappler G2.
    Thank you Sir.
    dont get the g1 [emoji28]
    inflate properly lng. to reduce sidewall damage
    Aug 2017
    #7056
    Thank you po
    #7057
    Thank you Sir.
    No issues with 275/55r20. I think there is one here who uses 285/55r20 mud tires and no issues either.
    Malambot ang nitto. Side walls easily tear, thread gets punctured even by g.i. wire. For porma ok pero for use on gravel and rough roads I will not buy another set. Grips very well on pavement though.
    Aug 2017
    #7058
    Thank you sa info, going 2 years na orig na gulong but need to check for a thicker replacement for more cushion. Any suggested option?
    Cheers!
    Feb 2003
    #7059
    Same here 2 years na Eve ko but still good and thick pa naman threads ng tire, but am planning to change to a smaller rims i.e. 17" with a thicker rubber naman. Any idea ng brand for a HT tires na ganun size? mostly kse AT rating . So bale based on online wheel calculator....the target rubber size would be 275/60R17
    #7060
    Quote Originally Posted by Jiggs View Post
    Make it 4-5% bigger diameter than oem. In my experience the oem tires are 4-5% smaller than what is needed for an accurate speedometer reading. By using a tire that is bigger by 4 to 5% gives you more accurate speed and fuel economy readings. So if 275/60r17 gives the same diameter as oem then maybe 275/65r17 will be better.
    I will be buying either accelera or thunderer next.
Ford Everest 2015
