Page 612 of 778 FirstFirst ... 512562602608609610611612613614615616622662712 ... LastLast
Results 6,111 to 6,120 of 7777
    Sep 2016
    #6111
    Quote Originally Posted by eido View Post
    sa winterpine pala ako nag pa kabit ng rear cam and harness
    Thank you sir [emoji106] How much po pakabit? Baklas po ba whole panel? Saan po pinadaan yung cable? My warranty issue ba pag nagpakabit? Sorry sir newbie here. Thanks again!
    May 2007
    #6112
    Quote Originally Posted by AspiringDon View Post
    1k+. call mo winterpine for details hindi ko na binusisi pag kabit
    Sep 2016
    #6113
    Thanks boss, you're the man [emoji106]
    May 2007
    #6114
    1.7k pala check ko resibo. 200 additional cable.
    sa titanium may setting to turn off drl sa dash setting?
    #6115
    Next year!
    Ford Australia has started testing the facelifted version of Everest, which is known as Endeavour in India. According to the recent spy shots by Car Advice, the Everest or Endeavour will get updates to the front including the LED DRL's and a new grille inspired by the Ford F-150 truck. The Australian spec version of the Endeavour will get radar cruise control with autonomous emergency braking (AEB), however, the Indian spec might not carry these safety aids.
    The 2018 Endeavour is expected to use the same powertrain as in the current generation Endeavour and will be powered by two diesel engines- 2.2 litre and 3.2 litre. The 2.2 litre engine delivers 158 hp of power and 385 Nm of torque,while the 3.2 litre engine produces 198 hp of power and 470 Nm of torque. The smaller engine comes with a 6-speed manual and automatic transmission, while the 3.2 litre diesel unit comes only with an 6-speed automatic transmission. The top end diesel also comes with an all wheel drive and a Terrain Management System.
    May 2007
    #6116
    hindi nag work forscan off road sa trend variant. hinahanap yung front cam. nag ka dtc error. meron nakapag enable ng off road sa trend variant?
    Apr 2009
    #6117
    wala. you gotta do it thru Forscan.
    #6118
    Question lang po. May nagpalagay ba ng screen protector or tempered glass sa head unit nila? Yung tulad po ng link sa baba.
    Galleon - LFOTPP Ford Focus Edge Everest Explorer Taurus Car Navigation Screen Protector Glass, Tempered Glass Center Touch Screen Protector Against Scratch High Clarity.
    May 2007
    #6119
    Quote Originally Posted by ferrarifan View Post
    Sa thailand ford everest forum na enable nila drl control via ipc/dashboard. Pero mukhang pang titanium lang.
    Jul 2017
    #6120
    Hi, I'm not sure if this is a noob question but I'll ask anyway. Mavovoid po ba ang warranty kapag nagpakabit ng led step sills sa Trend? Thank you.
Ford Everest 2015
