Page 310 of 778 FirstFirst ... 210260300306307308309310311312313314320360410 ... LastLast
Results 3,091 to 3,100 of 7777
    Mar 2016
    #3091
    Just want to confirm if anim ba talaga ang airbag ng Trend variant? Thanks.
    Sent from my HUAWEI MT7-TL10 using Tapatalk
    #3092
    ^^^ pagkaalam ko yes 6 airbags.
    1 driver
    1 passenger
    2 seat air bags (for the 2nd row passengers)
    2 curtain air bags
    missing is the driver's knee airbag which is only for the titanium models.
    Mar 2016
    #3093
    Kaya naman pala hindi mabenta ang AMBIENTE ang cheap ng interior napaka ordinary sa presyong milyon. yong side mirror parang material ng plastic stand fan. 216 FORD EVEREST AMBIENTE AT 2.2L 4x2 - QUICK LOOK | PHILIPPINES - YouTube
    Mar 2016
    #3094
    1 driver
    1 passenger
    2 curtain air bags
    Thanks.
    Jun 2010
    #3095
    May nag palit na ba ng aftermarket wheels ng titanium models?
    Sent from my ASUS_T00J using Tapatalk
    Mar 2016
    #3096
    Lack of GPS map on the HU was a major factor for me. Pero since i really wanted the looks of the Everest kaya in the end it wasn't a deal breaker.
    Any suggestions on a GPS unit na mag fit maganda sa cockpit ng everest? I use waze sometimes but I want a dedicated map while driving na accessible na isang pindot lang at wala ng setup pa. thanks.
    N.B. still back reading kaya pls forgive me if it was discussed already.
    Feb 2011
    #3097
    Quote Originally Posted by gomez_ea2 View Post
    Check mo tire pressure mo sir, bka di pantay. Pag nag break ka, kumakabig ba?
    Tire pressure is same 35 on both sides, brought my own gauge din noong pumunta ako sa ford, kasinayaw kong gamiting rason / palusot ng SA na un-even yung tire pressure.
    So pa dating ko doon, measured the tire pressure in front of thr SA may 1 psi diff kasi mainit goma.
    Had a couple of test drives with their mechanic and the acknowledged na merong kabig to the left pag naka center yung steering wheel.
    Solution: "sir ibalik mo nalang kasi wala pa po kame nung alignment values para sa bagong everest"
    On either easy or hard breaking, walang kabig.
    Btw i have a 3.2L titanium
    Feb 2011
    #3098
    Quote Originally Posted by rrdanas View Post
    Quote Originally Posted by Head-On View Post
    Might be due to fuel tank being on the left side. Read somewhere that this is also the cause why the T6 tilts to the left.
    Again, not sure about this. Not an expert here.
    My navara's fuel tank is also on the left, walang kabig
    Feb 2011
    #3099
    Quote Originally Posted by saiyan0728 View Post
    Yes it has 6 airbags. Actually may nakita ako sa dealership nug nag pa service ako trend na binangga ng truck sa rear passneger side, pumutok lahat ng airbag sa right side..
    Will post video link once i upload it.
    Mar 2016
    #3100
    wheel alignment siguro yan. experienced it on another car. had it aligned, and it worked.
Ford Everest 2015
