Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 54
    Dec 2013
    #41
    Grew up in mindanao drank straight from the tap for 16yrs.. Transferred here in manila used ceramic filter lang before mga 5yrs or so. Then 3-stage filter up until now. No problems naman...
    Oct 2013
    #42
    Quote Originally Posted by jmpet626 View Post
    Current setup ko.
    2 Stage filter connected sa Tap before going sa Pure It Excella. 1st Filter: Granular Activated Carbon 5 micron filtering 2nd filter: Carbon Block 5 micron filtering. Then I pour the filtered water sa Pure It Excella.
    Current setup ko.
    overkill naman yan... yong savings mo sa pureit napupunta dun sa filter cost mo sa unit before pureit...
    ang maganda sa pureit may users manual siya, anything printed wrong dun eh pwede mo i file ng law suit against them if it fails...
    Oct 2013
    #43
    dito sa amin sa muntinlupa, pwede na ang activated carbon ng tupuro kasi chlorinated naman siya ng maynilad... basta mataas ang pressure ng tubig ok para tulak palabas ang dumi sa under ground pipe at makita agad nasaan ang leak...
    ang problema kase dati, low water presure sa maynila, kaya pag may pump ka sipsip mo lahat ng dumi sa broken underground pipe, plus di mo makita nasaan ang leak...
    #44
    Im planning to do home filtration na rin. Nagkaroon ng amoebiasis baby ko. Not sure kung dahil sa tubig. Distilled siya before pero inunti unti nanamin palitan kaso eto naman nangyari. So balik distilled siya ngayon. Now kelangan ko na mag setup siguro ng home system kasi magastos yung laging distilled.
    Dec 2002
    #45
    We use Megafresh (FP-3-AG) 3 stage water filter system.
    Click image for larger version.
    Sa filter replacement kapag may sale sa Ace Hardware bumibili na ako.
    #46
    We buy. My Lola was convincing us last year to buy Kanjen. Now she thinks boiled water ia better than kanjen. Money wasted again
    Mar 2005
    #47
    Quote Originally Posted by Stigg ma View Post
    For some reason makalawang/maputik yung tap water sa area namin. Sa Secondary tank dami naipon na kalawang/putik kaya nag pre filter ako. Mabilis bumara pure it kung ganun which happened to my other friend, eh hassle din mag palit ng GKK ng pureit kasi ilang flushing pa gagawin mo para mawala yung plastic smell sa new pure it GKK kit. Mas bawas din yung chlorine taste pag nag pre filter ako ng Activated carbon and Carbon block.
    Nov 2011
    #48
    We use water filtration system, replaced with reverse osmosis 2 years ago bought for 9.5k only excluding ultraviolet.Click image for larger version.
Name:	ImageUploadedByTsikot Forums1452414466.248350.jpg
    #49
    Quote Originally Posted by RC-V View Post
    kaka order ko lang from lazada nito, dahil sa bwiset na aquabest na masyadong pa-star
    anyway, tama ba 1st sediment; tapos yun parang bato bato (alkaline?) 3rd is active carbon?
    plano ko sana double (bili ako ulit)
    bali 6 stage, 3x 1st stage, then alkaline, then 2 active carbon; or OA na?
    so far OK naman 1 week ko na gamit ito.
    #50
    Hwag mo i-last ang carbon, need mo another finer sediment filter para di sumama carbon sa tubig.
    Signature
Drinking water - purified at home or water refilling station
