Page 1 of 2 12 LastLast
Results 1 to 10 of 20
    Aug 2004
    Dear Technical Support:
    Last year I upgraded from Girlfriend 7.0 to Wife 1.0 and noticed that the new program began unexpected child processing that took up a lot of space and valuable resources. No mention of this phenomenon was
    included in the product brochure.
    In addition, Wife 1.0 installs itself into all other programs and launches during system initialization, where it monitors all other system activity. Applications such as Poker Night 10.3, Drunken Boys Night 2.5 and Saturday Football 5.0 no longer run, crashing the system whenever selected.
    I cannot seem to keep Wife 1.0 in the background while attempting to run some of my other favorite applications. I am thinking about going back to Girlfriend 7.0, but the uninstall does not work on this
    program. Can you help me, please!!!
    Thanks,
    A TROUBLED USER
    Dear TROUBLED USER:
    This is a very common problem men complain about, but is mostly due to a primary misconception. Many people upgrade from Girlfriend 7.0 to Wife 1.0 with the idea that Wife 1.0 is merely a UTILITIES &
    ENTERTAINMENT program.
    Wife 1.0 is an OPERATING SYSTEM and designed by its creator to run everything. It is unlikely you would be able to purge Wife 1.0 and still convert back to Girlfriend 7.0. Hidden operating files within
    your system would cause Girlfriend 7.0 to emulate Wife 1.0 so nothing is gained.
    It is impossible to uninstall, delete, or purge the program files from the system once installed. You cannot go back to Girlfriend 7.0 because Wife 1.0 is not designed to do this. Some have tried to install Girlfriend 8.0 or Wife 2.0 but end up with more problems than with the original system. Look in your manual under
    "Warnings-Alimony/Child Support".
    I recommend you keep Wife 1.0 and just deal with the situation. I suggest installing background application program C:\YES DEAR to alleviate software augmentation. Having Wife 1.0 installed myself, I might also suggest you read the entire section regarding General Partnership Faults (GPFs).
    You must assume all responsibility for faults and problems that might occur, regardless of their cause. The best course of action will be to enter the command C:\APOLOGIZE. In any case avoid excessive use of YES DEAR because ultimately you will have to give the APOLOGIZE command before the operating system will return to normal.
    The system will run smoothly as long as you take the blame for all the GPFs. Wife 1.0 is a great program, but very high maintenance. Consider buying additional software to improve the performance of Wife 1.0. I
    recommend Flowers 2.1 and Diamonds 5.0. Do not, under any circumstances, install Secretary With Short Skirt 3.3. This is not a supported application for Wife 1.0 and is likely to cause irreversible damage to the operating system.
    Best of luck,
    Tech Support
    Sauce for the gander...author likewise unknown.
    Dear Tech Support:
    Recently I upgraded from Boyfriend 5.0 to Husband 1.0 and noticed that the new program began making unexpected changes to the accounting software, severely limiting access to wardrobe, flower, and jewelry
    applications that operated flawlessly under Boyfriend 5.0. No mention of this phenomenon was included in the product brochure.
    In addition, Husband 1.0 uninstalls many other valuable programs such as DinnerDancing 7.5, CruiseShip 2.3, and OperaNight 6.1 and installs new, undesirable programs such as PokerNight 1.3, SaturdayFootball
    5.0, Golf 2.4, and ClutterEverywhere 4.5. Conversation 8.0 no longer runs and invariably crashes the system. Under no circumstances will it run DiaperChanging 14.1 or HouseCleaning 2.6. I've tried running
    Nagging 5.3 to fix Husband 1.0, but this all-purpose utility is of only limited effectiveness.
    Can you help, please!!
    Sincerely, XXX
    Dear XXX:
    This is a very common problem women complain about, but is mostly due to a primary misconception. Many people upgrade from Boyfriend 5.0 to Husband 1.0 with the idea that Husband 1.0 is merely an ENTERTAINMENT package.
    However, Husband 1.0 is an OPERATING SYSTEM and was designed by its creator to run as few applications as possible. Further, you cannot purge Husband 1.0 and return to Boyfriend 5.0, because Husband 1.0 is not designed to do this. Hidden operating files within your system would cause Boyfriend 5.0 to emulate Husband 1.0, so nothing is gained. It is impossible to uninstall, delete, or purge the program
    files from the system, once installed. Any new program files can only be installed once per year, as Husband 1.0 has severely limited memory. Error messages are common, and a normal part of Husband 1.0.
    Having Husband 1.0 installed myself, I might also suggest you read the entire section regarding General Partnership Faults [GPFs]. This is a wonderful feature of Husband 1.0, secretly installed by the parent
    company as an integral part of the operating system. Husband 1.0 must assume ALL responsibility for ALL faults and problems, regardless of root cause. To activate this great feature enter the command "C:\I
    THOUGHT YOU LOVED ME". Sometimes Tears 6.2 must be run simultaneously while entering the command. Husband 1.0 should then run the applications Apologize 12.3 and Flowers/Chocolate 7.8.
    TECH TIP!
    Avoid excessive use of this feature. Overuse can create additional and more serious GPFs, and ultimately YOU may have to give a C:\I APOLOGIZE command before the system will return to normal operations.
    Overuse can also cause Husband 1.0 to default to GrumpySilence 2.5 or worse yet, to Beer 6.0. Beer 6.0 is a very bad program that causes Husband 1.0 to create FatBelly files and SnoringLoudly wave files that
    are very hard to delete. Save yourself some trouble by following this tech tip!
    Just remember, the system will run smoothly, and take the blame for all GPFs, but because of this fine feature it can only intermittently run all the applications Boyfriend 5.0 ran. Husband 1.0 is a great
    program, but it does have limited memory and cannot learn new applications quickly. Consider buying additional software to improve performance. I personally recommend HotFood 3.0, Lingerie 5.3, and
    Patience 10.1. Used in conjunction, these utilities can really keep Husband 1.0 running smoothly.
    After several years of use, Husband 1.0 will become familiar and you will find many valuable embedded features such as FixBrokenThings 2.1, Snuggling 4.2, and BestFriend 7.6. A final word of caution! DO NOT, under any circumstances, install MotherinLaw 1.0. This is not a supported application and will cause selective shutdown of the operating system. Husband will run only Fishing 9.4 and Hunting 5.2 until MotherinLaw 1.0 is uninstalled. I hope these notes have helped. Thank you for choosing to install Husband 1.0, and we here at Tech Support wish you luck.
    :hihihi:
    If your call center supports this product, you've hit the jackpot in tech help calls. :D
    Dec 2003
    ayoko na magupgrade hehe
    Apr 2004
    pwede ba upgrade to girlfriend8.0 na lang?
    Pwede rin mag Dual OS :D
  6. FrankDrebin Guest
    Quote Originally Posted by theveed
    Linux na lang para "Open Source". :D
    Dec 2003
    multi os nalang para masaya hehehe
    Jun 2005
    hay naku, next time kasi before you upgrade, run system restore para makagawa ng check point. After upgrading, run system restore again. If everything runs out of hand, you can always restore everything from a clean checkpoint.
    reformat na lng.... :twak:
    Feb 2004
    bka mag ka virus pa
Upgrading from Girlfriend 7.0 to Wife 1.0?
