Results 21 to 30 of 41
September 12th, 2011 05:34 PM #21
September 12th, 2011 08:30 PM #22
Many thanks for this sir. I am well aware of the viscosity ratings but I have to admit the API and ACEA ratings are kinda confusing. I am even confused at my manufacturer's rating requiring only CD even if my engine is a direct inject CRDI engine with EGR. I might just get the CH or CI rated oils next time.
September 12th, 2011 09:57 PM #23
i suggest get something that can be used with euro2/with egr engines. as using a lower type of oil might foul your egr.
i've been using top1 SDO in my pajero fieldmaster and so far good results. noticeably less smoke talaga. at 270 pesos per liter, i would say that this is cheap na.
September 12th, 2011 11:05 PM #24
Where do you get your top 1 SDO oil sir? Is this a fully synthetic oil or semi? Im thinking now of getting Royal purple fully synthetic oil for my strada.
September 13th, 2011 10:12 AM #25
IMO, SAE 50 oil is i think too high a viscosity. SAE 40 is more than enough i think. as per the common guides, SAE 40 satisfactorily meets Philippine conditions.
Simply said, 4 things to look at:
1. Viscosity
2. API rating
3. Blend (mineral, synth)
4. preferred brand (synonymous to your budget)
September 13th, 2011 05:50 PM #26
A TOP1 SDO user for my 2010 Strada GLS.
I have used it for my 5K PMS and will still be using it for my upcoming 10k PMS. A satisfied user.
Try to email this address: info*top1oil.com.ph You can ask where are their distributors near you.
You can look for them * FB "TOP 1 OIL PHILIPPINES".
September 13th, 2011 06:12 PM #27
its semi-syn. i change oil naman every 5k km/6 months. they have it na everywhere. Banawe, Masangkay, Blumenttrit.
pinkamura blumenttrit * 270 pesos per quart.
most expensive is 300 pesos per quart. Banawe price. didnt haggle anymore becuase i only bought 1 quart that time.
other stores would remove the barcode pa. may 10 pesos rebate hehe dont know the logic for this.
as for royal purple, im not sure of the API rating will be sufficient for vehicles with EGR, so i couldnt comment.
September 13th, 2011 10:33 PM #28
hmmm. I would like to try TOP1. Heard a lot of good feed backs from users.
- Apr 2011
- 78
- Feb 2014
- 2,658
November 27th, 2024 10:44 AM #30in 2024...
suppose you got an old fashioned engine i.e. no turbo, no DI
would you rather get an oil rated w/ the latest api SP (with no acea rating)
or an older api SN but with acea a3/b4 rating
