Results 11 to 20 of 27
August 15th, 2012 05:46 PM #11
ah ganon ba... kasi taka lang ako kung slide na bakit pa siya aandar di ba? anyways... sana makatulong kay ts 'to...
- Aug 2012
- 21
August 16th, 2012 10:42 AM #12
August 16th, 2012 11:05 AM #13
Hindi naman sakal yung carb mo? I encountered that on a Corolla 1.3 before when we were playing around with the carb jettings. If the secondary was made smaller, humihina hatak under full throttle or high rpm.
- Aug 2012
- 21
August 16th, 2012 09:59 PM #14
- Apr 2009
- 1,902
August 16th, 2012 10:11 PM #15
- Aug 2012
- 21
August 16th, 2012 11:21 PM #16
- Apr 2009
- 1,902
August 17th, 2012 12:35 AM #17Nag-ganyan na dati carb Mazda 1.6 ko pero dahil kasi yun sa mushroom type filter na gamit ko at masyado ko nilaro yung ignition timing ko kaya nawala sa tono.
Kung all-stock naman yan at assuming na hindi sliding ang clutch, pwede nga yung sabi ni sir vinj na either barado na yung secondary jet ng carb mo (secondary jet yung nagsusupply ng mas maraming gasolina pag high rpm na) o masyadong advance or delayed yung ignition timing mo (or worst, barado or sira yung vacuum from distributor going to carb ignition advance [ito yung mechanically nag-addvance ng timing ng carb mo on higher rpms gamit yung diaphragm].
Pwede din sirang PCV valve. Nag-uusok na ba pag high rpm?
Madaming factors eh, maganda sir mag-rule out ka muna isa-isa.
Procedure ko yun sa Aisan carb sa Mazda ha, not sure Mikuni kasi yata ang sa Mitsubishi hindi ko alam kung pareho sila mechanically.
PM mo si duskylim or jick baka mas makatulong sila sayo.Last edited by isa1023; August 17th, 2012 at 12:38 AM.
- Aug 2012
- 21
August 17th, 2012 10:45 AM #18
- Jul 2003
- 573
August 17th, 2012 03:52 PM #191. humanap ka ng ibang auto technician
2. pa-check mo timing
3. pa-check mo distributor advancer kung ok pa
Kung kinakapos sa fuel, pupugak-pugak ang andar ng engine o kaya kung mali timing, magba-backfire yan.
- Aug 2012
- 21
August 20th, 2012 06:32 PM #20Timing issue daw sabi nung pinapagawan ko. Nilinis na rin yung carb. Thanks sa mga nagreply
