Page 6 of 18 FirstFirst ... 234567891016 ... LastLast
Results 51 to 60 of 174
    Tingin ko head gasket! Tsk tsk tsk. [emoji23]
    haha
    dagdag stress kay Cathy
    #52
    Wag ka na manakot [emoji24] Narinig naman ni uls yung engine saka golden pa color ng oil ko kahit more than a year walang change oil [emoji14]
    Sent from my SM-M127F using Tapatalk
    Eh yun sa radiator mo na check mo ba? Baka humalo na engine oil doon.
    Oil cooler leak.
    #53
    haha
    Nag leak engine oil sa spark plug.
    #54
    Fuel injector pa pala baka dapat na din palitan.
    Benta mo ba cath.
    #55
    Palit na rin siguro fuel pump assembly.
    #56
    Tapos hinde mo pa nagagamit baka bad gas, kailan ibaba fuel tank.
    Mar 2004
    #57
    Ignore Doc ... he's doing an old blue or whatever his new nick is ... you took care of the car well ... it's just a minor issue ...
    *shadow ...
    Cathy just had a panic attack ...
    Dec 2019
    #58
    Update on my issue:
    the rough idling and engine shaking or "dieseling" issue has resolved today when i replaced my no. 2 injector on the fuel rail. I've checked yesterday for the diagnosis for all of my injectors and they found that the injector no. 2 was the fault.
    #59
    *shadow ...
    How did you know? I seriously did have my palpitations again. Had to take Benadryl to calm me down (my doc recommended this for my anxiety)
    #60
    And the answer is IGNITION COIL! Valve cover gasket with oil leak too
    I called 2 people when I thought my car was gonna tirik. Si Ahya (car guy ko since teens) and ULS. Ahya said could be CVT problem. Natakot ako! Uls said ignition coil agad
    Those who said ignition coil, congrats hahaha! Thank you also to the rest that gave their insights. Kailangan na rin ng cleaning
    Can you guys check ano pwede tanggalin sa 40k or okay na lahat?
    Btw, I'd replace the 4 coils na as jick suggested.
    Ignition coil 2 din ang sira ng sakin. What is with the 2nd?!?!
Sudden Rough Idling/Car Shaking
