Page 4 of 390 FirstFirst 123456781454104 ... LastLast
Results 31 to 40 of 3899
    Dec 2007
    #31
    sir, do you have a fleetguard oil filter that can fit the 4m41?
    Sir, I am the owner of Devilsown Alcohol injection, the filter thing is more of a hobby, I am also still active duty U.S Navy until I retire next year. But I would be happy to provide you with the filter number for that engine.
    I do have a bunch of filters I will ship when I do retire late next year but that's a long time away, Like late June of Next year when I move to the Philippines for good.
    You can use a Fleetguard LF3830 or LF3564 or Baldwin BD28 WIX is also a good brand ant it's a 51067
    BPV Setting 100 kPa (14.5 PSI)
    Largest OD 110 mm (4.331 in)
    Overall Height 138 mm (5.433 in)
    Thread Size M26 X 1.5-6H INT
    You can find these fairly easy especially the WIX but they are not cheap. I'll pick up a few cases between now and next year I'm sure. These are just hard to find nothing really uses this thread size.
    Do a search and you will find plenty around most under 20USD. If you have someone visiting the states have them pick you up a few. Even I don't have any, and I got like 500 filters in my storage.
    #32
    Quote Originally Posted by miked View Post
    sir, where'd you get baldwin filters? i might make a manila trip come end of april and pass by that place.
    Baldwin shop is Volmax - I don't have their number right now. I'll give it out on Monday. The shop is on s padilla in Manila.
    Wix filters on the other hand is sold Superior Motors 3741737. It is near Quezon Ave.
    from what I have researched these are the two consistent high quality filters even in the US
    #33
    OT: hi dvldoc. I have a PM for you regarding alcohol injection that I got from you years ago.
    Dec 2007
    #34
    Quote Originally Posted by edtf View Post
    Wix is a excellent brand, actually one of the better over the counter filters. Just make sure it's the real deal.
    WIX Box should look like this. and if it does not say WIX Corporation, Gastonia N. C. made in USA on the back it's not the real deal.
    The other countries of production will be these. If no country of origin then it's not the real deal.
    Mexico
    Ukraine
    Venezuela
    Brazil
    Poland
    If they come in a plain white box with a Wix label stuck on, are white in color and they come in shrink warp plastic. They have the Wix part number stenciled in blue on the filter it's not the real deal.
    Two style boxes
    As you can see they are high quality filter, I got a bunch myself, If I see them on sale I pick them up.
    #35
    [SIZE="4"]So...saan ba nakakabili ng dual filtration system dito sa Manila?
    Tsaka pwede kayang maglagay ng secondary filter para sa diesel, yung tipong
    maglalagay muna ako filter na pang gas na nakaseries sa diesel fuel filter..?
    [/SIZE]
    #36
    got the number of Volmax. its 2448375.
    Baldwin for 4D56 is 765pesos.
    Bosch (Korea) naman, 350pesos.
    Dec 2007
    #37
    That's a pretty low price for a imported Baldwin, If it's a real on then it's a good deal.
    Let us know if you get one and if it's the real deal. It should be a Baldwin BD28.
    Jun 2007
    #38
    sir Dvldoc, quick question lang sir..
    is the Baldwin BD28 suitable for both 4m41 and the 4d56?
    because the OEM mitsu filters for both 4m41 and 4d56 not only has a difference in part number but also in size...the 4m41 being bigger....
    does it mean that the baldwin bd28 has a universal fit?
    #39
    i think the cheapest quality filter will be bosch..
    sir locoroco, try to call Volmax. im not sure if 4m40 and 4m41 has the same filter, but when i inquired regarding 4m40, wala daw.
    bosch lang meron. c/o warren auto supply
    Dec 2007
    #40
    The 4M41(OEM ME013307) filter would be the BD7028 also a combo filter and dual flow.
    BD7028
    Dual-Flow Lube Spin-on
    Anti-Drainback Valve
    20 PSID By-Pass Valve
    Thread: M26 x 1.5
    O.D.: 4 1/4 (108.0)
    Length: 5 27/32 (148.4)
    BD28
    Thread: M26 x 1.5
    O.D.: 3 11/16 (93.7)
    Length: 5 3/8 (136.5
    So to answer your question yes you can use it. Here's the thing with oil filters you can go bigger or smaller as long as you have space 1 or 2 inches will not make a bit of difference in most vehicles. It all depends on the space you have to work with different manufactures have different sizes for the same filter.
    The portant part to get right is the thread size, filter type, and by-pass valve.
    The BD28 is used for all those engines. The BD28 is physically a little smaller by very little.
Remote bypass oil filtration
